Hi guys,
I'm here with a WD usb drive. Crap...
Until recently I don't have last version of DE, so I couldn't use on the fly decrypt.
During this time, I sucessfully clone most part of th usb drive with a sata board.
So I got drive image... crypted.
Now, I have last version of DE.
Can I decrypt my crypted image with software otf decrypt?
Mount task as drive, something like this ?
I started to clone again with decrypt, but last time it take 3 weeks, due to large amount of errors...
Thanks for help and ideas
WD usb decrypt - the 2 ways
Re: WD usb decrypt - the 2 ways
I add an info :
original usb PCB seems well working. It is recognised in WD usb utility and I can work with.
ok, there is what I have done :
- copy sector-by-secor image file to another hard drive (WD)
- initiate disk in WD Marvel utility
- create new DE task, check decrypt, use file 25.rpm from original drive to have key.
Now I have access to data (thanks to Maxim from TS)
Greetings,
Greetings,
hddr49, Thank you! You and other customers are always welcome in ts.acelab.eu.com !
