ST4000LM016-1N2170 Low Current Spin
obxspook
Postby obxspook » 02.11.17, 08:40
So I was able to unlock the SA and save all the resources. 10 heads. All but one are acting normal. I was able to save all data from the 9 heads working normally. When I attempt to save data from the weak head, it will read then fail and lose readiness. When I restart the drive the terminal says this:
Boot 0x80M
Low Current Spin
FAIL Servo Op=0100 Resp=0007
0100 0001 0000 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1640 0087 8252 F180 0008 0000 0000 0000 0B88 0000 0000 0000 0000 0000 0000 0E2E 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
Here's where it get's kind of weird. If I leave it alone for a bit, it'll work again, become ready and allow data access again. Resistance between motor coils seems to be 2.4 Ohm (but I'm not completely sure I measured correctly) I don't have another drive of the same family to compare to.
Am I just looking at a bad head here or is it something else?
Re: ST4000LM016-1N2170 Low Current Spin
Postby DataMedics » 06.11.17, 15:38
I've seen the "low current spin" message on drives that were working perfectly fine, so I don't think that's anything to be concerned about.
I suspect the long wait until you have data access may relate to media cache or some background process that can probably be disabled in system file 93. Just be sure you have a backup of everything as I'm not totally sure this model is fully supported.
Postby Amarbir[CDR-Labs] » 06.11.17, 15:57
Sir ,
low current spin has nothing to do with this ,Did you clone MFT and then make a map of selected files and started cloning ,How much data is left on weak head if you have done this
obxspook
Postby obxspook » 06.11.17, 16:38
OK thanks, I suspected it has nothing to do with the low current spin, I just wanted to make sure. I have backups of all system files, media cache is disabled along with all the other usual stuff you want to do before a recovery. It's a 4TB drive that's almost completely full, so unfortunately the remaining head that's weak/bad has a little more than 350GB needed to be recovered off of it.
Postby DataMedics » 06.11.17, 17:02
Probably is clean room time then.
obxspook
Postby obxspook » 06.11.17, 18:11
DataMedics wrote:Source of the post Probably is clean room time then.
Which is thrilling with these newer tiny Seagates! Sometimes I wish I had baby hands!
Postby DataMedics » 06.11.17, 23:28
These tools can make it easier: https://apextoollab.com/
shahi
Postby shahi » 29.03.18, 08:27
I've a HDD that comes Ready after a while.
Diagnostic Port Locked.
Which family is it? and Is it supported to patch ROM to unlock diag port?
Postby AJ2008 » 29.03.18, 08:49
Check V4 log, probably there are many entries relating to poor head. Clear it and see if it improves. If not, then I suspect you will need to intervene and replace the complete head assembly
shahi
Postby shahi » 31.03.18, 01:28
AJ2008 wrote:Check V4 log, probably there are many entries relating to poor head. Clear it and see if it improves. If not, then I suspect you will need to intervene and replace the complete head assembly
I agree with you. But what family is it? Until I cant unlock diag port lock, nothing can be done
Postby AJ2008 » 03.04.18, 15:18
M10TDP family I think this should be, and should be unlockable in PC3K...
