HELP.! correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage . I't not Work!
Posted: 08.07.17, 08:17
by cuumaytinh
Seagate F3
Added correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage (for CFW ROM);
I try. But it not work.
- seagate sshd.jpg (486.4 KiB) Viewed 19994 times
Re: HELP.! correction to avoid hangup of hybrid drives Kahuna family in case of NAND damage . I't not Work!
Posted: 10.07.17, 22:09
by avalanche
Is any one from tech support able to explain the circumstances to which this patch should be applied? Is this to be used as an alternative to swapping a failed SSHD PCB with donor in instances of NAND failure?
Thanks,
A
Posted: 10.07.17, 22:20
by studiogsm
I'm also interested in this topic.
Posted: 11.07.17, 12:14
by Masterclass
Which FW version do you have?
Posted: 25.07.17, 06:02
by -BR-
Hi ACE Staff.
Can you please write an article on how to use the “Kahuna CFW patch 1” to fix Seagate SSHD?
Thank you
-BR-
