When starting utility, the Terminal shows logs as follows, Rotating is normal
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Tech Unlock Handshake: 0x544427EE
Reply:
after this i have tried """"""""Unlock Tech drive prepared by utility"""""""""then terminal shows as
Spin Up
SpinOK
TCC:001F
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
SNOOOZZZZZZEEE Retry
LED:000000EE FAddr:0030E020
Rst 0x40M
Is anybody help to recover data from this.
With regards
Sundar
ST2000DM001-FW-CC25 BUSY ERRO
Re: ST2000DM001-FW-CC25 BUSY ERRO
The issue is most likely related to the media cache. It's very common on Grenada family drives. Need to establish a terminal connection and tweak system file 93 to disable it.
Hello Sundar,
Can you read system file 93 by terminal?
If terminal is not available - try to short a reading channel on the PCB and check a terminal access by Ctrl+Z.
Is it available for now?
Thanks to all for your reply.
I am not able to get terminal access.. Reading channel short also no use. finally i have decided to drop the case and return to the customer.
With regards
Sundar
With regards
Sundar
datacare wrote:Source of the post Thanks to all for your reply.
With regards
Sundar
Wow, you give up quick. It takes a lot of practice to get the timing right when shorting these if the media cache is really acting up, but it generally can be done (unless it's one of the really new ones where the terminal is totally locked)
Data medics,
Why would you think the "RECOV Servo Op=0900 Resp=0005" relates to media cache when "RECOV Servo Op=0900" usually indicates a head issue?
If it were bad heads on this model, it'd click and spin back down. OP said it's spinning normally. Possibly it has some firmware corruption as well, but I doubt heads in this case.
I am not able to o read ROM through BOOTCODE option . Any body can tell the " shortpoint " of the particular model.
once again I wanted to read the ROM information via boot code access. I wanted to disable one head of hdd
please throw some lights on it...
crystal
crystal
