Dear Frds ...
I have received 320 GB wyatt family F/w : 0002BSM1 , reading partially 0 - 300000000 LBA sector only total 298.09 GB (625 142 448) ..Please give me any solution for this case
St932032As partial access on LBA
Re: St932032As partial access on LBA
Any one knows please update frds
What was original symptoms when you received this case?
same reading problem friend ...
Can you post output from V40 here?
Rst 0x08M
(P) SATA Reset
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
F3 T>
Thank you
(P) SATA Reset
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>V40
F3 T>
Thank you
NRG is empty and since you have partial translator loaded I assume NRG entries were cleared during some translator rebuild.
Did you try to run Recovery Translator option?
YES I try to rebuild but same result finally ..
Did Translator Recovery option complete or did it give error about correcting manually?
If i run translator ,Lots of UNC error is coming and not completed ,I have stop that translator recovery
Thank you frds ,please give me your suggestion
hello frd
Please update ..
Please update ..
