Seagate ST3000DM001
unspoken
Seagate ST3000DM001
Postby unspoken » 13.06.16, 11:44
Hello Folks, i have to say that DM series makes crazy.
My patient drive ST3000DM001. First problem was No ID and access terminal. i solved that issue and drive worked. When i was clone Head1 was weak. Disabled it and contunie to cloning. When cloning process at %40 i cant read any sector at udma mode. But i can read with utility but very slowly. i head swaped and worked well, i started clone again with udma mode. maybe 2 hours later i havent read any sectors again. But still read sectors with utility as slowly.
cleared the smart. nothing changed.
tried translator regen still same.
edit id unchecked all box, still same.
i had no success for recover translator.
i wanna show the log..
i need any advice please.
HDD family detecting...
Family ID: 58
Selected family......................... : 58, Grenada
Model by ID............................. : ST3000DM001-1CH166
Loading default settings!
Then press OK!
Tech Key...
Requesting FW Pkg ver ........ GPX17D.CCD2.DC0CAL.CC29
Detecting Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 6
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
Reading Registry File...
Parsing Registry File...
Media Cache
MC : disabled
MC Size : 0x43FFA0
MCMT Ver : MCMTV05
ID Len
0 36 Reserved Defect Table (SA defect table)
3 7782 Primary Defect File (P-List))
8 4800
B 1000
C 122880 Serial Port Test Results File (Self Scan Log)
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
26 80 Drive Self Test (DST), Head 4
27 80 Drive Self Test (DST), Head 5
2B 10118 R/W Operating Parameters (translator, etc)
2F 432 Data Integrity Check (DIC), HEAD 4
30 432 Data Integrity Check (DIC), HEAD 5
33 4576
39 8192
3A 4
3D 3072
3E 3072
3F 4576
40 7
41 2180
42 4096
43 10241
44 1939440
45 808580
46 226172
47 226172
48 226172
49 226172
4A 226172
4B 8192
4F 14336
51 18432
52 1024
53 8192
54 3984384
Collecting DT Infos...
ID MemOffs Len
0 40030200 40944 Read Adaptive Parameters File (RAP)
1 40030000 512 Controller Adaptive Parameters File (CAP)
4 1D400 7168 Servo Adaptive Parameter File (SAP)
40002000 13288
total 20456
A 25EA50 1024 Seek Profile
13 401393F8 1440 Dependent Zone Table for User Area
14 40139998 120 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1D 40030220 424 VBAR Configuration File
1E 400305B8 4016 Zone Format Parameters File
26 40136F28 9424
27 40136D30 504
ID MemOffs Len
2 400303C8 496 Zone Table
40002000 13288
total 20456
6 1915C40 81964 Servo Flaw Table
16 40030200 32 Drive Configuration Table
17 400319A0 2016 Temperature Control Configuration
1F 4032C8E8 4500 RW working user preamp table
20 4032DA80 150 RW working system preamp table
26 40136F28 9424
27 40136D30 504
Collecting DT Infos completed
Searching CFW OVL FID in RAM............ Ok
Test : Reading modules
Reading modules to profile folder
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Grenada\ST3000DM001-1CH166-CC29-Z1F4FMQ2\Data\ModDir\
Module 0000, Reserved Defect Table (SA defect table).................. : Ok
Module 0001, Drive Information File (DIF)............................. : Ok
Module 0002, Performance Parameter File (PPF)......................... : Ok
Module 0003, Primary Defect File (P-List))............................ : Ok
Module 0005, Manufacturing Information File (MIF)..................... : Ok
Module 0008........................................................... : Ok
Module 000B........................................................... : Ok
Module 000C, Serial Port Test Results File (Self Scan Log)............ : Ok
Module 000D........................................................... : Ok
Module 000E, Data Integrity Check (DIC), HEAD 0....................... : Ok
Module 000F, DIC Dummy File........................................... : Ok
Module 0013, Disc Registry File (settings, security, etc)............. : Ok
Module 0015, BGMS File (Directed Offline Scan)........................ : Ok
Module 0016........................................................... : Ok
Module 0017........................................................... : Ok
Module 0019, Log File................................................. : Ok
Module 001A, Log File................................................. : Ok
Module 001B, Log File................................................. : Ok
Module 001C........................................................... : Ok
Module 001D, Physical Overlay File 0.................................. : Ok
Module 001E, Physical Overlay File 1.................................. : Ok
Module 0022, Drive Self Test (DST), Head 0............................ : Ok
Module 0023, Drive Self Test (DST), Head 1............................ : Ok
Module 0024, Drive Self Test (DST), Head 2............................ : Ok
Module 0025, Drive Self Test (DST), Head 3............................ : Ok
Module 0026, Drive Self Test (DST), Head 4............................ : Ok
Module 0027, Drive Self Test (DST), Head 5............................ : Ok
Module 002A, Saved Mode Pages (HDD settings).......................... : Ok
Module 002B, R/W Operating Parameters (translator, etc)............... : Ok
Module 002C, Data Integrity Check (DIC), HEAD 1....................... : Ok
Module 002D, Data Integrity Check (DIC), HEAD 2....................... : Ok
Module 002E, Data Integrity Check (DIC), HEAD 3....................... : Ok
Module 002F, Data Integrity Check (DIC), HEAD 4....................... : Ok
Module 0030, Data Integrity Check (DIC), HEAD 5....................... : Ok
Module 0033........................................................... : Ok
Module 0034, Packed CONGEN XML definition............................. : Ok
Module 0039........................................................... : Ok
Module 003A........................................................... : Ok
Module 003D........................................................... : Ok
Module 003E........................................................... : Ok
Module 003F........................................................... : Ok
Module 0040........................................................... : Ok
Module 0041........................................................... : Ok
Module 0042........................................................... : Ok
Module 0043........................................................... : Ok
Module 0044........................................................... : Error
Error : Out of memory
Modules reading process completed
Test : DT reading
Reading DT to profile folder
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Grenada\ST3000DM001-1CH166-CC29-Z1F4FMQ2\Data\CPDir\
DT 0000 (Flash ROM), Read Adaptive Parameters File (RAP).............. : Error
Error : Rq Rd DT part ID 0, Offs 0x0 err! Tech state 0x72, 0x05260207
DT 0001 (Flash ROM), Controller Adaptive Parameters File (CAP)........ : Ok
DT 0004 (Flash ROM), Servo Adaptive Parameter File (SAP).............. : Error
Error : Rq Rd DT part ID 4, Offs 0x0 err! Tech state 0x72, 0x05260207
DT 0005 (Flash ROM), Servo Firmware Table............................. : Ok
DT 000A (Flash ROM), Seek Profile..................................... : Ok
DT 0013 (Flash ROM), Dependent Zone Table for User Area............... : Ok
DT 0014 (Flash ROM), Dependent Zone Table for System Area............. : Ok
DT 0015 (Flash ROM), Flash ROM........................................ : Ok
DT 001D (Flash ROM), VBAR Configuration File.......................... : Ok
DT 001E (Flash ROM), Zone Format Parameters File...................... : Ok
DT 0026 (Flash ROM)................................................... : Ok
DT 0027 (Flash ROM)................................................... : Ok
DT 0000 (RAM), Read Adaptive Parameters File (RAP).................... : Ok
DT 0001 (RAM), Controller Adaptive Parameters File (CAP).............. : Ok
DT 0002 (RAM), Zone Table............................................. : Ok
DT 0004 (RAM), Servo Adaptive Parameter File (SAP).................... : Ok
DT 0005 (RAM), Servo Firmware Table................................... : Ok
DT 0006 (RAM), Servo Flaw Table....................................... : Ok
DT 000A (RAM), Seek Profile........................................... : Ok
DT 0013 (RAM), Dependent Zone Table for User Area..................... : Ok
DT 0014 (RAM), Dependent Zone Table for System Area................... : Ok
DT 0015 (RAM), Flash ROM.............................................. : Ok
DT 0016 (RAM), Drive Configuration Table.............................. : Ok
DT 0017 (RAM), Temperature Control Configuration...................... : Ok
DT 001D (RAM), VBAR Configuration File................................ : Ok
DT 001E (RAM), Zone Format Parameters File............................ : Ok
DT 001F (RAM), RW working user preamp table........................... : Ok
DT 0020 (RAM), RW working system preamp table......................... : Ok
DT 0026 (RAM)......................................................... : Ok
DT 0027 (RAM)......................................................... : Ok
DT reading process completed
Re: Seagate ST3000DM001
Postby Amarbir[CDR-Labs] » 14.06.16, 06:09
Well,
This is Cos of RAP/SAP Parameters not being read or some issue with them
unspoken
Postby unspoken » 14.06.16, 09:32
Thanks Amarbir. How can i fix that? Any advice?
Postby Amarbir[CDR-Labs] » 14.06.16, 10:07
unspoken wrote:Source of the post Thanks Amarbir. How can i fix that? Any advice?
How Many Head Drive is This 6 ? .Now Can You Read all Sectors From start From All Heads ? .
unspoken
Postby unspoken » 14.06.16, 10:58
Yes, Drive has 6 heads. i can read all sectors via active pc3000 utility. so very slowly.
Postby Amarbir[CDR-Labs] » 14.06.16, 16:06
unspoken wrote:Source of the post Yes, Drive has 6 heads. i can read all sectors via active pc3000 utility. so very slowly.
Well,
Can you cross check if you can read sectors at good speed fro all heads for a few sectors from all heads or you have to use active utility from start only
Postby AJ2008 » 24.06.16, 16:57
Check NRGL. If translator was rebuilt based on PLIST but without NRGL then some NRGL defects may be preventing access to data in normal read mode. In most cases where translator is rebuilt without NRGL defects access via utility is often still possible.
Can you post output from V40 here?
unspoken
Postby unspoken » 27.06.16, 10:32
AJ2008 wrote:Source of the post
Thanks A2008 for reply.
case solved and cloned %100.
i've tried to recover translator and got success! :thumbup:
Postby AJ2008 » 27.06.16, 17:01
Great result 8)
