how to choose multiple items to del in plist defect edit menu?
Re: how to choose multiple items to del in plist defect edit menu?
In The Picture I Can See That Happening .Can You Please Elaborate The Question Once again
Try to delete a group, instead of choosing one by one. such as, use shift-key + page down key, or just use mouse, like most of window application.
But this function does not work for pc-3000 here.
Thanks.
Thanks.
Hello oldman,
Shift+ method doesn't work in defect lists. Method you selected on picture will delete 5 items. It is mentioned on pop window.
oldman wrote:Source of the post how to choose multiple items to del in plist defect edit menu?
Thanks for reply, any easy way for me to delete more instead of one by one to "click" each item?
Dmitriy_TS wrote:Source of the post Hello oldman,oldman wrote:Source of the post how to choose multiple items to del in plist defect edit menu?
But,
The Way Windows Normally Lets You Select Is The Way That Can Be Added To the Tool right Sir
