how to choose multiple items to del in plist defect edit menu?
oldman
Postby oldman » 03.04.16, 21:54
Re: how to choose multiple items to del in plist defect edit menu?
Postby Amarbir[CDR-Labs] » 04.04.16, 15:43
In The Picture I Can See That Happening .Can You Please Elaborate The Question Once again
oldman
Postby oldman » 04.04.16, 16:15
Try to delete a group, instead of choosing one by one. such as, use shift-key + page down key, or just use mouse, like most of window application.
But this function does not work for pc-3000 here.
Thanks.
Nick_TS
Postby Nick_TS » 04.04.16, 21:08
Hello oldman,
oldman wrote:Source of the post how to choose multiple items to del in plist defect edit menu?
Shift+ method doesn't work in defect lists. Method you selected on picture will delete 5 items. It is mentioned on pop window.
oldman
Postby oldman » 05.04.16, 00:08
Thanks for reply, any easy way for me to delete more instead of one by one to "click" each item?
Postby Amarbir[CDR-Labs] » 05.04.16, 13:11
Dmitriy_TS wrote:Source of the post Hello oldman,
But,
The Way Windows Normally Lets You Select Is The Way That Can Be Added To the Tool right Sir
