M15 Family
zeroalpha
M15 Family
Postby zeroalpha » 25.11.22, 02:27
Anyone have any success with M15 Family? Ace still working on a solution.
Model : ST5000LM000-2U8170
Serial : WCJ5LR19
Firmware : 0001
Capacity : 5 TB (9 767 541 168)
Boot0x80M
SpinUp
TCC:001D
Trans
Rst0x80M
T:0x0001 0x0DDF8086
FTU
TCC:001D EMCDataErr:0000000E
PrgF
(P)SATAReset
RAWOFF
PASS
Secondaryislatest!-00000001
Primaryisobsolete
[MCMTW_DSW]Primary-000ABC85LPCDisc=01447AC94E00C5
PrgF
6GbMaxSpeedloweredto3GbforIntelbug
SendStatus:COMRESETseen
CSpd=3Gbps
FIS34
[BRO-0002]00447AB378-00447AC94DExtents-0001Blk-00000000D-00000001
FAILServoOp=06DFResp=0007
06DF0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
ResponseFrame00000216FFFFFFF000080000000000000EB60000000000000600000019AA002E00000000000000000000000000000000000000000000000000000000000000000029Loop=2247
DSC FAIL
ServoDiscSlipFailedErrCode=0415018B
FAILServoOp=000EResp=000B
000E0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
ResponseFrame26720011FFFFFFF000080000000000000EB60000000000000600000019AA002E00000000000000000000000000000000000000000000000000000000000000002247
FAILServoOp=0995Resp=0007
0995A26900057FFF7FFF7FFF000000000000000003E80000FFFF8DC000000081004C00000000000000008C603F8CA00000000000000000000000000027000000
ResponseFrame26720011FFFFFFF000080000000000000EB60000000000000600000019AA002E00000000000000000000000000000000000000000000000000000000000000002247Loop=2247
0995A26900057FFF7FFF7FFF000000000000000080000000FFFF8DC000000081004C00000000000000008C603F8CA00000000000000000000000000027000000
ResponseFrame001400100004C62C2001BD70E92D41F0F6FFFB5B000000004D00000019AA084A0000000000000000000000000000000000000000000000000000000000000000FFFFLoop=2247
Doomer
Re: M15 Family
Postby Doomer » 25.11.22, 17:28
Yes
zeroalpha
Re: M15 Family
Postby zeroalpha » 29.11.22, 07:51
Doomer wrote:Source of the post
Yes
You can unlock tech mode?
Doomer
Re: M15 Family
Postby Doomer » 29.11.22, 19:23
zeroalpha wrote:Source of the post
Yes, I can
zeroalpha
Re: M15 Family
Postby zeroalpha » 30.11.22, 01:50
Yes, I can
are you making useless posts or are willing to prove it?
Doomer
Re: M15 Family
Postby Doomer » 30.11.22, 18:44
I accept cases if you want to outsource.
The proof
Code: Select all
M15.JanusR2.SBP3.SATA.Servo376.Rap30RevA.4K + SMR Despo DFW BP3
Product FamilyId: CF, MemberId: 01
HDA SN: WCJ5xxxx, RPM: 5527, Wedges: 178, Heads: A, OrigHeads: A, ActiveHdMap: 03FF, Lbas: 0000496B6B5D, PreampType: 82 50
Bits/Symbol: C, Symbols/UserSector: 0, Symbols/SystemSector: 0
PCBA SN: 0000C1527WEM, Controller: JANUS_R1_SATA(2310), Channel: Unknown, PowerAsic: KONA Rev A042, BufferBytes: 8000000
SF ID: EF 60, SF Part Size: 800, Flash Used: 800
Package Version: M2AEA13B0.SDM4.410012.0001    , Package P/N: 200456700, Package Global ID: 00305567,
Package Build Date: 12/15/2020, Package Build Time: 20:01:33, Package CFW Version: M2AEA13B0.SDM4.410012.02093578.00305567.0001    ,
Package SFW1 Version: B0BE, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 12152001, CustomerRel: 0001, Changelist: 02093578, ProdType: M2AEA13.SDM4, Date: 12/15/2020, Time: 200133, UserId: 00305567
Servo FW Rev: B0BE
TCG IV Version: 40.02
Package BPN: 7
RAP FW Implementation Key: 1E, Format Rev: 000A, Contents Rev: 11 19 01 00
Active BFW Container: 0
4K Sys Area: 1
Features:
- IOEDC enabled
- IOECC enabled
- DERP  enabled v. 7.0.00.0000000000000000
- LTTC-UDR2 compiled off
- SuperParity 4.1 enabled OTF OC enabled
   TotalSuperBlks     TotalValidSuperBlks
   003C865D           003C8659
- Humidity Sensor disabled
- Media Cache Partition enabled
- Media Cache enabled
- Low Current Spin Up enabled
- Torn Write Protection enabled
- SubRelease:0
- Critical Event Log v. 1
- FAFH 70.0 disabled
- EWP:0
- DRAM Mirror:0
- FwSRN:0004 SfwSRN:0004 CID:01
Doomer
Re: M15 Family
Postby Doomer » 03.12.22, 22:10
So, your client needs data and you lack the tools. Outsourcing will be a smart move here.
HX-20
Re: M15 Family
Postby HX-20 » 05.12.22, 13:13
Or you could just share the love, Mr Doomer?
Doomer
Re: M15 Family
Postby Doomer » 05.12.22, 16:06
HX-20 wrote:Source of the post
I would like to get paid for all the work I've done.
If you think it's not worth it then you can do the research yourself.
HX-20
Re: M15 Family
Postby HX-20 » 06.12.22, 14:36
Are you selling or will you only support outsourced cases?
Doomer
Re: M15 Family
Postby Doomer » 06.12.22, 16:56
Outsource only
Maxim_TS
Re: M15 Family
Postby Maxim_TS » 07.12.22, 08:05
Dear Customers, please note that all manipulations made not by ACELab engineers and PC-3000 equipment you are doing on your own risk.
ACELab developers are working on such a solution for M15 family, we hope to provide a solution in the near future.
