SSHD ST500LM000
Re: SSHD ST500LM000
Postby Amarbir[CDR-Labs] » 18.03.16, 17:10
avalanche wrote:Source of the post It has been possible to get access to LBA values on the patient HDD. The disk is imaging. Once I have inspected the results later today I shall provide a full write up to method of recovery.
Do Keep us posted plus i have a few questions but after your results
avalanche
Re: SSHD ST500LM000
Postby avalanche » 18.03.16, 17:45
The disk is imaging OK. However, Data Extractor is reading some data from the Flash buffer on the donor PCB which is creating pseudo logical data. The patient HDD only has EXT4 filesystem on it, and with the donor PCB I am picking up traces of NTFS partitions, with a date modified of the date on which I ordered the donor HDD (i.e. a few days after the patient HDD was received in for recovery).
Does anyone know how to flush out the Flash buffer. My attempts to do this have not yet been successful.
Best regards,
J
avalanche
Re: SSHD ST500LM000
Postby avalanche » 18.03.16, 18:01
I've sorted out the best way to clear the buffer now, and I'm only getting the correct EXT4 filesystem which should exist on this SSHD. I'm finishing in the office shortly, so just going to get the device imaging for recovery. When this is complete I will write up a method on what was done.
IMP
Re: SSHD ST500LM000
Postby IMP » 19.03.16, 05:01
We will wait the full write up and method of recovery.
Re: SSHD ST500LM000
Postby Amarbir[CDR-Labs] » 20.03.16, 07:46
Dmitriy_TS wrote:Source of the post
huangmiaofang wrote:Source of the post
1: reading the original disk ROM
2: Read spare ROM
3: Load Spare disk ROM
4: Replace CAP RAP SAP
5: Load LOD, this process fails, wait one minute, do not de-energized.
6: re-power, again loaded LOD.
7: Start copying data
Thank you for this procedure.
dataq wrote:Source of the post Thanks for the info.
Regards John
Could you share with us your results?
Dimitry Sir ,
Why should this work .Is this what he is trying to tell us
1 : We Read Patient ROM
2 ; Read Donor ROM
3 : Load Donor ROM He Means Right
4 : Replace CAP RAP SAP ( Where In Patient Or Donor ,Possibly He Means To Say From Patient To Donor )
5 : Load LOD [ LOD of Patient or Donor Very Confusing ]
6 : Re Power Again [ Load LOD Again Same Question LOD of Patient or Donor ]
7 : Copy Data Why Not But Understanding above procedure is necessary
Re: SSHD ST500LM000
Postby Amarbir[CDR-Labs] » 20.03.16, 07:52
avalanche wrote:Source of the post I've sorted out the best way to clear the buffer now, and I'm only getting the correct EXT4 filesystem which should exist on this SSHD. I'm finishing in the office shortly, so just going to get the device imaging for recovery. When this is complete I will write up a method on what was done.
Sir ,
By Buffer Flushing Are you Referring To NAND Flash Cleaning So That You Get Data Of Platter Only .
Nadpc3k
Re: SSHD ST500LM000
Postby Nadpc3k » 27.03.16, 01:19
Hi avalanche ... were you successful .. can you write down the procedure here as you mentioned .. i have one drive unable to get to clone
dataq
Re: SSHD ST500LM000
Postby dataq » 29.03.16, 16:02
Hi Avalanche,
Did you manage to get a good image. We still have a ST500LM000 drive here with no spin. Have you a process to overcome issue.
Regards John
gterry
Re: SSHD ST500LM000
Postby gterry » 01.07.16, 16:14
Hi avalanche or anyone else,
Did the final procedure for this ever come out? Thanks in advance.
avalanche
Re: SSHD ST500LM000
Postby avalanche » 01.07.16, 19:11
Sorry, I had been meaning to write this up, then Easter came. I will get round to it asap, but the technique used is pretty much Amarbir has written with a couple of extra bits. The difficulty is donor part compatibility - the criteria is not what you might normally expect. The donors I used (and other SSHDs) are currently on loan at another UK data recovery company as they were really struggling to get spares on a disk they had in. I might have another SSHD or two in stock; I should run through the process with these again. Just a matter of trying to find time....
paweliusz
Re: SSHD ST500LM000
Postby paweliusz » 16.09.16, 16:49
Hello, Team, can anyone give me LDR file for drive ST500LM000-1EJ162 FIRMWARE : DEM4
Thanks it will be highly appreciated
Marek
Re: SSHD ST500LM000
Postby Marek » 04.11.16, 21:36
I little dont understandt this procedure. May i please someone to explain step by step? not in 1.2.3.4.5. ???
IMP
Re: SSHD ST500LM000
Postby IMP » 05.11.16, 05:48
1 : First Read ROM of the PATIENT Drive / RECOVERY Drive and SAVE
2 ; Secondly Read the ROM of the DONOR Drive ( WOrking and having similar FW code as Patient Drive ) and SAVE.
Also SAVE Loader of the Donor Drive
3 : Now Start your Patient drive with the PCB of Donor Drive.
4 : Now in Utility go to work with "Flash ROM Image file" and Load Donor ROM and then Replace CAP RAP SAP from Patient ROM
Write / Save this Hybrid ROM to the same PCB which is currently connected to the Patient Drive.
Power cycle it should work.
Marek
Re: SSHD ST500LM000
Postby Marek » 22.11.16, 12:27
Something strange. We doing this procedure but we dont have SA access and we can read only few first sectors of HDD to image...
I ask in pw avalanche to can help me understand but dont answer me. Maybe IS too BSY to help :-(
gterry
Re: SSHD ST500LM000
Postby gterry » 22.11.16, 14:48
Maybe some at ACE LABS can help?? Maybe a new support blog on it?
