ST2000LM007-1R8174 FW:EB01 utility compatibility
hdd00
Re: ST2000LM007-1R8174 FW:EB01 utility compatibility
Postby hdd00 » 13.03.21, 08:44
Yes, that's also a Rosewood AF. Unfortunately, if it gives you that error, it means it's not fully ready to work on ATA because of MC error in firmware. I'm afraid you can't do anything more without unlocking Rom first.
Rgds
osity
Postby osity » 14.03.21, 21:52
Does the latest software version provide an unlock patch for Rosewood AF?
hdd00
Postby hdd00 » 15.03.21, 06:29
Yes, of course.
osity
Postby osity » 15.03.21, 16:05
Sounds good.
osity
Postby osity » 16.03.21, 19:11
Software updated, but patch did not work. No handshake option. I'll have to contact support.
osity
Postby osity » 16.03.21, 21:19
I must have been doing something wrong with the patch as all rosewood patches are the same. Ts unlocked it using what appeared to be the exact same process as I was using. Handshake appeared right away.
Case is now solved with Media Cache contents preserved with help from TS.
Thanks for all the help.
jimmy
Postby jimmy » 18.03.21, 09:53
Hi osity,
We have similar experience why TS can patch but we cannot, just have cup of coffee and try again. :D
elbote83
Postby elbote83 » 12.07.21, 01:10
Has anyone resolved the problem with the patch?
Masterclass
Postby Masterclass » 12.07.21, 11:23
Use patch #2
elbote83
Postby elbote83 » 12.07.21, 16:34
it didn't work
osity
Postby osity » 12.07.21, 20:25
Masterclass wrote:Source of the post Use patch #2
What is patch #2 for anyway?
Maxim_TS
Postby Maxim_TS » 13.07.21, 16:07
osity wrote:Source of the post What is patch #2 for anyway?
Patch 2 is for MakaraPlus family mostly.
Regarding Rosewood AF, it's necessary to write the patched ROM twice. Second time after the first failed attempt.
elbote83
Postby elbote83 » 16.07.21, 04:14
Maxim_TS wrote:Source of the post
it worked, thanks
