Yes, that's also a Rosewood AF. Unfortunately, if it gives you that error, it means it's not fully ready to work on ATA because of MC error in firmware. I'm afraid you can't do anything more without unlocking Rom first.
Rgds
ST2000LM007-1R8174 FW:EB01 utility compatibility
Re: ST2000LM007-1R8174 FW:EB01 utility compatibility
Does the latest software version provide an unlock patch for Rosewood AF?
Yes, of course.
Sounds good.
Software updated, but patch did not work. No handshake option. I'll have to contact support.
I must have been doing something wrong with the patch as all rosewood patches are the same. Ts unlocked it using what appeared to be the exact same process as I was using. Handshake appeared right away.
Case is now solved with Media Cache contents preserved with help from TS.
Thanks for all the help.
Hi osity,
We have similar experience why TS can patch but we cannot, just have cup of coffee and try again.
Has anyone resolved the problem with the patch?
- Masterclass
Use patch #2
it didn't work
osity wrote:Source of the post What is patch #2 for anyway?
Patch 2 is for MakaraPlus family mostly.
Regarding Rosewood AF, it's necessary to write the patched ROM twice. Second time after the first failed attempt.
Maxim_TS wrote:Source of the postosity wrote:Source of the post What is patch #2 for anyway?
it worked, thanks
