Good day,
I've this Seagate Rosewood hard drive, it spins up smoothly but does not ID-ed and stays BYS always
Model: ST1000LM035
FW: SBM3
Terminal log
Bad CRC Seg:0x06
LED:0x000000BB FAddr:0x00004A18
Ctrl + Z doesn't work
It will be very much appreciated if anyone here know how to go about it?
Seen SMP flags issue (by Acelab) on Youtube, the terminal error is totally difference from my case.. wondering if this is something I should try?
Thanks in advance.
Best regards
Seagate Rosewood Busy Status
Re: Seagate Rosewood Busy Status
BootFW in ROM is corrupted, could be the result of incorrect unlock patch or perhaps you didn't read or write the full ROM.
Doomer is right
Recheck that you selected correct family name 9not F3 common) write back ROM from the backup and re-do patching (in proper family utility) again.
Doomer is right
kennethwy, contact us at support with this case, also send the ROM file saved under Rosewood family.
Hi guys,
Thanks Doomer, Filipp and Maxim for your advise. Appreciate that
with help from Dmitriy yesterday, all data are fully recovered.
Thanks again guys!
Thanks again guys!
- Dr.Computador
kennethwy wrote:Source of the post Hi guys,
Thanks Doomer, Filipp and Maxim for your advise. Appreciate that!!
Thanks again guys!
Hi guys
I have the same problem, ST2000LM007 Bad CRC Seq:0x06, could you help me ?
Users browsing this forum: Bing [Bot] and 11 guests
