get acces to terminal with : Tech mode unlocking preperatin than i tried to Unlock tech, drive prepared by utility.
terminal reply -> Diagnostic Port locked. Its possible to unlock these drive? Fam: 79 Crawford.
Any hint is welcome.
Niceday
AJ2008 wrote:Source of the post does it eventually show DSC and DRD after the terminal has stopped spamming these addresses?
Amarbir[CDR-Labs] wrote:Source of the postAJ2008 wrote:Source of the post does it eventually show DSC and DRD after the terminal has stopped spamming these addresses?
Aj Sir ,
i am of the opinion there is a need to remove reallocations in SMP sys file in this current drive .I also feel there is need to work on media cache in this particular drive case .We in india are still not having higher capacity drives coming .But in states and canada and many parts of europe its very common
AJ2008 wrote:Source of the post this would require access via terminal which seems to not be granted based on the initial post.
AJ2008 wrote:Source of the post Latest update will support this
