Dear friends ..
I was in problem ,Seagate St1000DM003 Some sector are not reading ,i have done all of basic translator recovery and translator failed in pc3000 ,Some most important data present i that sectors ,Any one kindly help me ,i have team viwer ..Please help me
ST1000DM003 - Some sector are not reading
Re: ST1000DM003 - Some sector are not reading
redlabs, unreadable only some sectors at the middle of the drive, or you can not see the end of drive? How many LBA do you read? What after F3 T>V4 and V40?
Maxim_TS wrote:Source of the post redlabs, unreadable only some sectors at the middle of the drive, or you can not see the end of drive? How many LBA do you read? What after F3 T>V4 and V40?
i can read end of the sector , i cannot read middle of drive ,After running V4 V40 ,Same result ..it is one TB hard disk i can read upto 950000000 crore after that 1750000000 i can read please help us ...
redlabs wrote:Source of the postMaxim_TS wrote:Source of the post redlabs, unreadable only some sectors at the middle of the drive, or you can not see the end of drive? How many LBA do you read? What after F3 T>V4 and V40?
"Fork" searching: 913458481 - 1953525167
HDD Redynes timeout (10000)
Surface scanning timeout!
Grow up the ATA timeout then restart auto-recovery or proceed manually!
LBA : 913458481
redlabs wrote:Source of the postredlabs wrote:Source of the postMaxim_TS wrote:Source of the post redlabs, unreadable only some sectors at the middle of the drive, or you can not see the end of drive? How many LBA do you read? What after F3 T>V4 and V40?
LBA : 913458481
Maxium please help me
Hello friends ,,
Anyone knows please share the idea .. i am waiting
If you get access to the first and to the last LBA then there is no something problem with translator and unavailable sectors can be bad head(s), scratch on the surface or bad blocks.
If you can't read from someone LBA till the end of drive then it's problem with translator. Follow blog articles or contact Technical support regarding your case.
P.S.
As you can see for such procedure utility ask to grown up timeout value.
You can do it in utility settings.
P.S.
redlabs wrote:Source of the post "Fork" searching: 913458481 - 1953525167
LBA : 913458481
