i have problem with seagate ST500LM000
Model : ST500LM000-1EJ162
Serial : W370PQPD
Firmware : LVD2
HDD family detecting...
Family ID: 72
Selected family......................... : 72, Kahuna_5400
Model by ID............................. : ST500LM000-1EJ162
Loading default settings!
Then press OK!
Tech Key...
Requesting FW Pkg ver ........ KH6T6C.LVM3.DW0JAN.LVD2
Detecting Phys Sct Size...
Result.................................. : 4096
Detecting Max Head number...
Phys. heads............................. : 2
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C001000 - 0x0001FFFF (0x0000000F)
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
ID Len
0 36 Reserved Defect Table (SA defect table)
3 7782 Primary Defect File (P-List))
8 4800
9 1 SMART Configuration File
A 3905 SMART Data File
B 1000
C 122880 Serial Port Test Results File (Self Scan Log)
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
2B 10118 R/W Operating Parameters (translator, etc)
33 4576
35 26 SMART Data
39 8192
3A 4
3D 3072
3E 3072
3F 4576
40 7
41 2180
42 4096
43 10241
44 247724
45 123862
46 123862
4B 8192
4F 4096
51 18432
52 1024
53 8192
54 2048
Collecting DT Infos...
ROM:
ID MemOffs Len
0 40030200 40944 Read Adaptive Parameters File (RAP)
1 40030000 512 Controller Adaptive Parameters File (CAP)
4 1D400 7168 Servo Adaptive Parameter File (SAP)
40002000 13288
total 20456
A 25E3E4 1024 Seek Profile
13 4013A208 1440 Dependent Zone Table for User Area
14 4013A7A8 24 Dependent Zone Table for System Area
15 0 1048576 Flash ROM
1D 40030220 424 VBAR Configuration File
1E 400305B8 4016 Zone Format Parameters File
26 40137260 12200
27 401371E8 120
RAM:
ID MemOffs Len
2 400303C8 496 Zone Table
40002000 13288
total 20456
6 13DBA40 81940 Servo Flaw Table
16 40030200 32 Drive Configuration Table
17 400319A0 2016 Temperature Control Configuration
1F 4032A9E0 4800 RW working user preamp table
20 4032BCA0 80 RW working system preamp table
26 40137260 12200
27 401371E8 120
Collecting DT Infos completed
Reading autotuning buffer............... Ok
Searching module table in RAM... ....... Error
Searching volume 3 file table in RAM.... Error
Searching volume 0 file table in RAM.... Ok
Searching SMP RAM FID in RAM............ Error
Searching Non Resident G-List FID in RAM Error
Searching CFW OVL FID in RAM............ Error
Searching DT table(RAM, WR) in RAM...... Ok
Searching DT table(RAM, RD) in RAM...... Ok
System Files I/O method detection... ATA(direct)
terminal :
PowerState = IDLE2
HighPowerMode
TCC:0025
Status 0001 Req 0002
PowerState = IDLE1
PowerState = IDLE2
APM disabled by SPort
ASCII Diag mode
F3 T>
ASCII Diag mode
HighPowerMode
TCC:0022
Status 0001 Req 0027
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
i cant read data from this hdd
im try Clearing Non Resident G-List, Recover translator,Translator regeneration
but not success!!
some body hell me?
thank alot !
seagate ST500LM000 somebody hell me?
Re: seagate ST500LM000 somebody hell me?
It's an SSHD, so I'd suspect it's a problem with the NAND chip. Not exactly sure how you disable it on this one.
Are you sure it is spinning?
lcoughey wrote:Source of the post Are you sure it is spinning?
yes..im sure
MINH
DataMedics wrote:Source of the post It's an SSHD, so I'd suspect it's a problem with the NAND chip. Not exactly sure how you disable it on this one.
If we can disable the NAND - how to do it ?
MINH
Hello ,
i think the new update has some support for this drive ask TS staff specially to maxim filipp and roman
Users browsing this forum: Bing [Bot] and 10 guests
