Seagate 4TB hdd has clicking noise. It has head crashed. I have replace the head.
Now No cliking noise. Motor is runing smoothly. Terminal shows this message.
"Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Disc FW failed to load"
How to resolve?
St4000dm000 After Head change Message Disc FW failed to load
Thanks,
Amit Shah
Arihant Data Recovery, India
Amit Shah
Re: St4000dm000 After Head change Message Disc FW failed to load
You need to get terminal access and check heads reading and writing via terminal. Then check important sysfiles. Maybe you will need to upload loader
REplaced the pcb and solved.
Thanks,
Thanks,
Thanks,
Amit Shah
Amit Shah
Did you need to swap 1 ROM chip or 2?
- Amarbir[CDR-Labs]
osity wrote:Source of the post Did you need to swap 1 ROM chip or 2?
What,
I Think They Have Only 1 Rom
I thought so too.
my drive stopped spinning after it was imaging fine for a while. I remove the TVS and it was fine for a few minutes and then stopped spinning again.
I changed the PCB/rom and the drive now spins again but I get this FW Error and the drive now detects as 3.68GB.
