ROM version............................. : 05.BME
ROM generation.......................... : 05.BME
Link table version...................... : 04.3D.
Head map................................ : 2,3,4,5,6,7
Firmware version........................ : 000500BM
Additional info from label:
DATE: 19 FEB 2009
DCM DANNNT2MFB
Anyone got modules/loader for this drive ?
thanks
WD10EAVS-32D7B1 (KERMIT)
Re: WD10EAVS-32D7B1 (KERMIT)
I have some Kermit resources, but nothing matching the firmware you need sorry.
what is the problem with your Kermit?
on power on it stays busy. sa seems to have no defects, i can read all cyls (-1 to -170), all heads (2 - 7, HM is 234567). i suspect bad pcb or logical damage to sa. the latter i cant sort out since i dont have any resources on these drives. this drive sounds normal on power up and wasnt dropped/didnt have power surge. cylinders on head 2 and 3 (main/backup sa i think) are identical. any ideas?
thanks
thanks
Do you still need this resources?
David
David
no, thank you.
i managed to read sa tracks and wrote tool to extract the modules. then i did a hot swap and got the data.
thanks for asking,
swersig
thanks for asking,
swersig
Thats good news. I suspect you had a weak head preventing correct translator initilisation, this has been talked about in different topics.
