The PC-3000 comes with one USB terminal PCB. Is it possible to use 2 at the same time?
(i.e: One on SATA0 and one on SATA1)
Can you use 2 terminals on the PC-3000 UDMA?
Re: Can you use 2 terminals on the PC-3000 UDMA?
Yes, you can use 2 at a time (and I assume more). The pc3000's drive utility will automatically ask which you want to use in a pop-up window if necessary.
Nice. Is there any available in North America or does it have to come all the way from Russia?
- GuideRecovery
i have tested more than 2 terminals, there is no problem.
Wasim Zafar
https://mindmergepk.com
Wasim Zafar
They ship from Russia or Europe, but if I recall, it only takes 2-3 days (though shipping will cost similar to the card itself, so I'd try to order a few things at the same time that you might not have like the wd 3.5 and 2.5 terminal connectors, etc. to make it more worth the shipping).
You can use one of these if you'd like a really inexpensive option: http://www.ebay.com/itm/1pc-USB-2-0-to- ... 1046646242
(I've tested, it does work)
Or you can get one just like the original here: http://www.ecrater.com/p/15286631/pc-30 ... 2511193139
(odd the word c.h.e.a.p. gets filtered???? that's strange)
