Can you use 2 terminals on the PC-3000 UDMA?
osity
Postby osity » 12.05.17, 16:55
The PC-3000 comes with one USB terminal PCB. Is it possible to use 2 at the same time?
(i.e: One on SATA0 and one on SATA1)
ThomasH
Re: Can you use 2 terminals on the PC-3000 UDMA?
Postby ThomasH » 12.05.17, 17:43
Yes, you can use 2 at a time (and I assume more). The pc3000's drive utility will automatically ask which you want to use in a pop-up window if necessary.
osity
Postby osity » 12.05.17, 22:11
Nice. Is there any available in North America or does it have to come all the way from Russia?
GuideRecovery
Postby GuideRecovery » 13.05.17, 09:33
i have tested more than 2 terminals, there is no problem.
Wasim Zafar
https://mindmergepk.com
ThomasH
Postby ThomasH » 15.05.17, 00:17
They ship from Russia or Europe, but if I recall, it only takes 2-3 days (though shipping will cost similar to the card itself, so I'd try to order a few things at the same time that you might not have like the wd 3.5 and 2.5 terminal connectors, etc. to make it more worth the shipping).
Postby DataMedics » 15.05.17, 21:24
You can use one of these if you'd like a really inexpensive option: http://www.ebay.com/itm/1pc-USB-2-0-to- ... 1046646242
(I've tested, it does work)
Or you can get one just like the original here: http://www.ecrater.com/p/15286631/pc-30 ... 2511193139
(odd the word c.h.e.a.p. gets filtered???? that's strange)
Return to “Data Extractor”
