.MTS file header
Lux
.MTS file header
Postby Lux » 21.08.09, 13:34
Hi to all.
I would like to perform a GREP/Raw search in order to recover .MTS files (High Definition VIDEO stream).
The problem is that this kind of file is not included in my database; I don't know file structure and cannot find nothing useful on internet (header string to be precise).
Does anyone knows the right string to add a new file type in Grep search module?
Thank you very much!
Lucio
Lucio
steven
Re: .MTS file header
Postby steven » 22.08.09, 04:06
You can check it from A working sample MTS file
Lux
Postby Lux » 24.08.09, 11:46
steven wrote:You can check it from A working sample MTS file
The problem is that I haven't a such file nor I can't download it from the web....
I can find only .m2ts files...
:wink:
Lucio
steven
Postby steven » 24.08.09, 12:39
is it possible to ask a sample file from your client.
-BR-
Postby -BR- » 27.08.09, 07:15
I have a couple of .mts files from our company Sony HD cam
Header is:
474000100000B0110000C100000000E01F0001E100235AAB82FFFFFF
@offset 4 (not 0)
But if I remember right, using raw recovery with .mts files will bring broken results because the header repeats itself through the file
If you have such a problem, e-mail me, I might have saved my custom search solution when i faced this problem before
I was able to recover all the files from a formatted hdd
Btw, vlc and super are good softwares for testing .mts files
Good luck
-BR-
Lux
Postby Lux » 27.08.09, 10:30
-BR- wrote:Hi
Header is:
@offset 4 (not 0)
Good luck
-BR-
HI BR!
Thank you very much for your help!
Yes I noticed that header in .mts files is repeated.
I can confirm you that vlc is a very good reader for both .mts and .m2ts files.
Please, where can I write to you and obtain your help? In your profile I cannot find an email addreess.
If you prefer, you can contact me at
lucio.ciccarelli@search-tec.it
Thank you again!
Lucio
betty
Postby betty » 22.02.14, 09:02
Hello everybody,
any one can advice me for the best solution for .MTS file recovery
Betty
Crystal
Return to “Data Extractor”
