I need help fo HFS+ data recovery
hassan
Postby hassan » 19.10.10, 07:45
I have 1TB drive with HFS+ file system
The client format this drive with NtFS file system and he dos not write any thing after the format function
I need the data which was on HFS file system it is about 600GB
Total LBA on this drive :1953525167
I do this steps to get data
1>I run GREP search for HFS structures
i find HFS+ Volume Header at LBA 409642 and 1853262982
also i find HFS+ Boot at LBA 1952982270
2> I assign all as Virtual HFS partition all was valid and refer to the same start of HFS Boot sector
3>Scan CatalogFile and Scan partiton but no thing found
What can i do to recove data?
Monk
Re: I need help fo HFS+ data recovery
Postby Monk » 19.10.10, 09:39
You could use another software for automatic recovery, like R-Studio, it might yield better results. You can also try RAW recovery in Data Extractor.
DE AD
hassan
Postby hassan » 19.10.10, 09:56
Thank you for help Monk
but i need the data with directory structures
R-Studio recover data for HFS+ with file type only
Postby AJ2008 » 19.10.10, 12:08
hassan wrote:Thank you for help Monk
No, this is only the case in situations of serious logical damage. If there is severe logical damage, then DE will fail to get structures also.
arvika
Postby arvika » 20.10.10, 23:31
Try HFS Explorer. It is free :)
Return to “Data Extractor”
