PC3000 installed, but status register lights do not show
crobison
Postby crobison » 03.10.17, 19:28
The green power status light works, but the register lights do not come on...
Re: PC3000 installed, but status register lights do not show
Postby DataMedics » 03.10.17, 20:55
Do you have a confirmed good drive attached to the channel?
crobison
Postby crobison » 04.10.17, 01:11
Drives are good..
hipo
Postby hipo » 04.10.17, 15:39
Did you connect Power cable to the board?
Sistrum Data Recovery
http://Www.datarecovery.mk
Blizzard
Postby Blizzard » 05.10.17, 01:27
Is it possible you are on channel1 but you have channel0 power connected to the drive? Have you checked the connections at the PCIe card?
jojo2012
Postby jojo2012 » 05.10.17, 14:37
Try changing PCIe slot, and checking the cable connections, also reverse the sata cables.
