help to recover data frm sd card 256gb
deyaa2012
Postby deyaa2012 » 23.06.24, 19:55
Lexar SD 256gb Not initialized give cmd8 no answer in sd card adapter
WhatsApp Image 2024-06-23 at 21.03.36_8f9f3bc8.jpg (224.31 KiB) Viewed 361021 times
Re: help to recover data frm sd card 256gb
Postby Roman_TS » 25.06.24, 09:11
Hello. It must be SM2704-based SD card with BGA-132/BGA-152 inside. We recommend you to do a chip off. For such cards we even have a good translator which will allow us to build a good image with File Structure.
deyaa2012
Postby deyaa2012 » 02.07.24, 16:57
can you guide me what to select from these as it is give me error i make chip off and inserted in adapter 152
WhatsApp Image 2024-07-02 at 18.04.09_54f0d8da.jpg (414.98 KiB) Viewed 360937 times
d_d_recovery
Postby d_d_recovery » 02.07.24, 18:30
Could be the wrong adapter, a bad chip, or its not been cleaned enough.
We need a lot more information to be able to help you.
deyaa2012
Postby deyaa2012 » 02.07.24, 19:21
these adapter i used and shape of chip after desoldering and cleaning kindly have alook and advise
WhatsApp Image 2024-07-02 at 20.27.08_0663390a.jpg (265.52 KiB) Viewed 360931 times
WhatsApp Image 2024-07-02 at 20.27.08_95d19b54.jpg (85.98 KiB) Viewed 360931 times
WhatsApp Image 2024-07-02 at 20.27.08_7d0e4e1d.jpg (147.29 KiB) Viewed 360931 times
d_d_recovery
Postby d_d_recovery » 02.07.24, 19:51
You might want to smooth those pads a little more.
And move the chip in the reader slightly each time you try to read it as these are not automatically centered.
Postby Roman_TS » 03.07.24, 09:44
This NAND is BGA-132, which is thinner than BGA-152, so you should place it directly in the middle of the adapter, it's important for a good contacts. In case of any troubles - please contact ACE Lab TS dpt. We will guide you with recovery steps: ts.acelab.eu.com
deyaa2012
Postby deyaa2012 » 03.07.24, 16:26
Dear Check i tried smoothing pad and centered chip in adapter but give me error as attached kindly advise smoothing pad ok or you still doubt about something
WhatsApp Image 2024-07-03 at 17.31.23_f1851b1e.jpg (301.68 KiB) Viewed 360918 times
WhatsApp Image 2024-07-03 at 17.31.24_62e71a06.jpg (339.96 KiB) Viewed 360918 times
WhatsApp Image 2024-07-03 at 17.31.23_9b599c68.jpg (237.64 KiB) Viewed 360918 times
WhatsApp Image 2024-07-03 at 17.31.23_c63d815b.jpg (75.56 KiB) Viewed 360918 times
WhatsApp Image 2024-07-03 at 17.31.22_1402a867.jpg (107.77 KiB) Viewed 360918 times
Postby Roman_TS » 03.07.24, 16:54
Please make a ticket, our engineers will guide you.
Postby Roman_TS » 03.07.24, 17:41
It's reading now. New generation of Micron NAND with 2.45V VCC and 1.8V VCCq
Controller is SM2704
Postby Roman_TS » 09.07.24, 10:01
Case was solved in PC-3000 Flash 9.0.21
italyassistance
Postby italyassistance » 18.09.24, 15:19
i have same problem with
Pen drive Philips 128gb
Controller IS918
Chip: PF667-25AR
cleaned perfectly, I insert it into the BGA-152 reader, but it only gives me the incorrect ID 0x0000, is the chip burned or do I have to set the power?
Postby Roman_TS » 19.09.24, 09:16
Hello. You should try to set 2.45V during the ID reading and check. After that, most likely you will need to adopt chip ID parameters for this NAND and set 2.45V inside.
Anyway, better to ask such questions in ACELab TS :)
italyassistance
Postby italyassistance » 19.09.24, 10:57
Thanks Roman, i have update for u, nand read 2.000 V and CQ 1.800 id 2C2CD31C 32C60000
Postby Roman_TS » 19.09.24, 16:32
Yeah, it's the new Intel/Micron low voltage chips. With a very bad quality...
