Hi Friends
SK hynix (HFM256GDJTNG) BC501 with HFB1M8M0331A controller. I can't find contacts to transfer to safe mode. If someone has encountered this ssd, please help.
m2 SK hynix
- Southman343
Re: m2 SK hynix
SAFE MODE will block access to NAND chips array, so you would be able work with the drive RAM + CPU. Not sure how exactly it should help
- Southman343
Re: m2 SK hynix
The problem is that the loader does not load due to an error in transferring the drive to safe mode, but thanks for the advice
Re: m2 SK hynix
But there is no Sk Hynix Utility in PC-3000 SSD, and no available loaders for this type of CPU.
It's a BGA-SSD drive, where controller, RAM and NAND chips are integrated into a common silicon layer.
Users browsing this forum: Bing [Bot] and 1 guest
