Hello, I have the following disk:
Model: PBT480GS25SSDR
Manufacturer: PATRIOT
Capacity: 480 GB
Cover Label: PE000390
P-1545
Controller Label:
PHISON
PS3110-S10-2
U01533C
SNSCT1DC
I attached the pins shown in the picture attached, and uploaded loader12 the utility cannot make the translator, i attached the log file
any one can help. Please not the attached pic when i start in safe.
thank you
Patriot Plast cannot make translator
- Attachments
- log.log
- (75.35 KiB) Downloaded 835 times
Re: Patriot Plast cannot make translator
It's a very good case description. The only problem is that PC-3000 Forum - is not the place where TS engineers can guide you with such specific case. So please, make a ticket on ts.acelab.eu.com and we will help you.
Thank you Roman, MY TS contract just expired, preparing to renew in one month, so, cannot post the ticket
Is the short pins for safe mode correct
You can contact ACELab even if your contract has been expired.
Shorting pins you marked are correct.
When i try to write a ticket.. it allows only registration issue.. can you tell me the link..
Thank you
Thank you
We are working already.
