Tips to unsoldered this nand
Typical Flash recovery cases
Flash
Postby Flash » 03.05.23, 11:36
Hello Guys,
Does anyone have tips to unsoldered this memory nand ?
Many thanks
Alain
Belgium
SGdata
Re: Tips to unsoldered this nand
Postby SGdata » 03.05.23, 19:23
I would rather solder it from the controller side.
d_d_recovery
Postby d_d_recovery » 03.05.23, 20:21
Flash wrote:Source of the post
Hello Guys,
Can you show a good quality picture of the other side of the PCB.
Postby Roman_TS » 04.05.23, 10:44
It could be eMMC with switched off internal
Better to check the controller name and try to use Spider to read the NAND via controller pads:
https://blog.acelab.eu.com/pc-3000-flas ... emory.html
Flash
Postby Flash » 05.05.23, 14:05
Thanks guy and Roman,
The controler is CHIPBANK CBM2098S
Many thanks
Alain
Belgium
Users browsing this forum: Baidu [Spider] and 1 guest
