BX500-CRTL 2259XT-Loader not found
jojo2012
Postby jojo2012 » 14.11.22, 11:37
as subject I get loader not found when I load them from the list.
Should I try them all?
I saw that the 2259XT controller is in the list of supported controllers in the "Silicon Motion", family "Silicon Power Slim S55 utility"
Jojo
Log-Loader-error.log
(5.32 KiB) Downloaded 776 times
Re: BX500-CRTL 2259XT-Loader not found
Postby Roman_TS » 15.11.22, 09:16
SM2259XT is under limited support. All depends on what type of the firmware inside and who is the NAND manufacturer.
Try all existing loaders from the list, one by one. Probably you will find compatible one.
jojo2012
Postby jojo2012 » 15.11.22, 11:41
Roman_TS wrote:SM2259XT is under limited support. All depends on what type of the firmware inside and who is the NAND manufacturer.
Thanks so much Roman, ok I'll try all existing loaders.
jojo2012
Postby jojo2012 » 16.11.22, 23:24
Roman_TS wrote:Source of the post SM2259XT is under limited support. All depends on what type of the firmware inside and who is the NAND manufacturer.
I found the compatible one, or at least the one that allows me physical access, but as you can see from the log it tells me that "The specified number of chips (8) does not correspond to the number of detected chips (4)!" and I cannot build the translator as you can see from the log.
Loader uploading
MPISP code name......................... : T0929A0 IMB37_00; T0701A(N)
Write "T0929A0 IMB37_00; T0701A(N)"..... : Ok
Calling executable code................. : Ok
Seed table reading
Completed
Microcode reading (0)................... : Ok
Firmware version (Internal)............. : T0710A0 MB37R_00
SSD parameters reading.................. : Ok
Loader not found by internal name.
Search for compatible loaders...
No compatible loaders found.
Select manually.
Write "U0326A0 HYNV6_00; T1030A(N)"..... : Ok
Reset SSD controller.................... : Ok
Write "Config Package".................. : Ok
Write "U0326A0 HYNV6_00; P0812(D)"...... : Ok
SSD status:
SSD is in ready state................... : Yes
Firmware mode........................... : DBG
SSD error code.......................... : 0x00 (No errors)
SSD is locked........................... : No
SSD is in Safe Mode..................... : No
Physical access is possible............. : Possibly
Microchips information uploading........ : Ok
System Info:
Chips id................................ : 0x2CC37832EA10
Vendor.................................. : Micron
Type.................................... : 128L(B37R) TLC 16k
Chip capacity........................... : 71 040 Mb
Channels................................ : 4
Chips (Total)........................... : 0x08
Planes per chip......................... : 4
LUNs per chip........................... : 1
Blocks per chip......................... : 0x02E4
Pages per block......................... : 0x1800
Page size............................... : 0x4000
Max retry level......................... : 0x00
Attention! The specified number of chips (8) does not correspond to the number of detected chips (4)!
First page not found
Reassigned block table loading.......... : Operation aborted
CP table loading
CP blocks not found
Completed
CP blocks not found
CP 0004 not found
USER password........................... : No
Postby Roman_TS » 17.11.22, 09:32
You've better to make a ticket :)
jojo2012
Postby jojo2012 » 17.11.22, 11:50
Roman_TS wrote:Source of the post You've better to make a ticket :)
Ok Roman
hdd00
Postby hdd00 » 18.11.22, 07:21
I have a drive exactly like this, with the same chips ID, and I have the same errors when I try to load loaders. So I'm interested how this ends.
Return to “Other SSD Crucial”
