TOSHIBA MQ04UBD200 in sector edit same LBA different information
net2
Postby net2 » 21.03.21, 20:48
Please I need to understand what is happening because I cannot find information to explain what I am looking.
1. I received a drive Toshiba MQ04UBD200 (USB) clicking
2. Change heads with a donnor.
3. Change PCB with a compatible one G4311A and I program the chip with a ROM programmer.
4. Drive was not clicking and PC3000 detected and read fast.
5. Made a HDD Resources Backup.
6. With Sector edit I could read the LBA 600.000 (Image 1): (https://drive.google.com/file/d/16QvtmC ... sp=sharing)
7. I could see the structure folder.
8. Turn off drive.
PROBLEM: :shockable:
9. I disconnected the drive and after a while I connected again and now I cannot see the folder structure :cry:
10. Change heads again with a brand new donnor (though was heads damaged), but same behaivor, cannot see the folder structure.
PLEASE Help me to understand this :umnik: :
With sector edit I read the LBA 600.000 (as before) and now the information is different (image2 after): https://drive.google.com/file/d/1GJ6fVE ... sp=sharing
Why the information I read with the same sector edit is different?
Thank you :thumbup:
Image1 Before.jpg (285.33 KiB) Viewed 25919 times
Image2 After.jpg (10.52 KiB) Viewed 25919 times
Re: TOSHIBA MQ04UBD200 in sector edit same LBA different information
Postby AJ2008 » 22.03.21, 10:08
Are you reading sectors normally or using utility read option?
d_d_recovery
Postby d_d_recovery » 22.03.21, 19:06
I know its a PITA when some one mentions the obvious but I am going to anyway.
After a head swap, once you get a drive live never switch it off if you have a choice, you may never get it live again.
You are not alone, we have all done it at one time.
net2
Postby net2 » 23.03.21, 00:55
AJ2008 wrote:Source of the post Are you reading sectors normally or using utility read option?
Yes both times, after turn on and detected by pc3000 the Toshiba got AMN error, so read with utility in sector edit. Same procedure.
Maybe do you know why the information is different? (same drive, same procedure, same LBA), I cannot understand what I am not looking :shockable:
net2
Postby net2 » 23.03.21, 00:57
d_d_recovery wrote:Source of the post I know its a PITA when some one mentions the obvious but I am going to anyway.
After this drive I learned :umnik:
Pd: Now I am doing a RAW recovery.
Alwasatgate
Postby Alwasatgate » 18.02.23, 10:45
Hello guys ,,
it's smr drive ?
any solution for it or still ? if the translator problem ?
Return to “Toshiba native”
