SandForce based SSD
Re: SandForce based SSD
Postby Roman_TS » 06.03.19, 08:10
se134 wrote:Any news?
Hello se134,
You can see the list of supported drives here. As soon as we will add SandForce drives in support list, we will announce it in our main web site, and list of supported drives in blog would be updated.
osity
Postby osity » 17.09.19, 15:30
I'm hoping for a solution to this as well.
northwind
Postby northwind » 18.09.19, 09:33
We can handle those, but it's quite costly :)
lcoughey
Postby lcoughey » 18.09.19, 13:12
northwind wrote:Source of the post We can handle those, but it's quite costly :)
While I can appreciate that the cost is justified by the complexity of the recovery, it is a shame that the majority of SandForce SSD recovery cases go unrecovered simply because the cost is just too high for the majority of owners. I do hope that there is a breakthrough soon so that we can make it more affordable and help more people get their data back.
protontech
Postby protontech » 24.07.20, 10:57
Is there anyone who also play with SF controllers and temperature? In this week, I got 3 different SF case, each drive stuck at busy, without reach rdy state. After reball and cool down under -10C SSD got ready and I can read the whole drive, without any error.
It's a very interesting for me. I know that lower temp=lower resistance, but I want to know that I have very big luck with this cases or It can really help the SF controllers in deathrow.
FredW
Postby FredW » 05.08.20, 16:31
@protontech Thanks a lot for the new approach :D Did you reball the Sandforce controller and/or the memory chips as well?
protontech
Postby protontech » 09.10.20, 11:41
FredW wrote:Source of the post @protontech Thanks a lot for the new approach :D Did you reball the Sandforce controller and/or the memory chips as well?
Dear FredW, in my case, reballing just the controller was enough, but since, I got case where memory reball also needed. For this "solution" the drive have to be in good logical condition, because translator building and any other logical action is imposible.
osity
Postby osity » 10.02.21, 18:19
I have a Kingston SSDNOw 200 V+ 120GB. Comes ready but then goes BSY after you try to read it.
Sandforce Chipset 2281VB1
Is this drive still unsupported?
lcoughey
Postby lcoughey » 10.02.21, 20:02
Power it off, create a task in DE, allowing it to power it on. If it IDs, power it off again and send the command to image. If it doesn't read, you need to send to Northwind in Greece or ACE in Texas.
osity
Postby osity » 11.02.21, 01:32
Appreciate the tip lcoughey. I will give it a shot in the morning and report back.
osity
Postby osity » 19.02.21, 19:30
Trying the Lcoughey technique now, does the drive have to be shorted at all? If not, my drive can't be recovered with that method.
I'll have to contact Northwind in Greece or ACE in Texas.
SGdata
Postby SGdata » 19.02.21, 20:26
There's no point of shorting it. If you have no way to rebuild the translator it's pointless. The only way is to run it as it is.
Postby Roman_TS » 20.02.21, 19:09
When you short the drive in SAFE MODE you just block access to the NAND chips. That's all what you are doing. It can help to reach READY state and work with CPU-RAM if drive was in BSY (loop of uploading damaged FW attempt-reset-uploading-reset-uploading and etc), but data will remain to be on the NAND and be unavailable for you. You need a loader to make it work after SAFE MODE.
RDDmx
Postby RDDmx » 12.09.24, 05:01
Any news or time frame?...
Postby Roman_TS » 12.09.24, 14:59
One day - definitely :)
Return to “Other SSD”
