MQ02ABF050H cannot read sector
thanhtn
Postby thanhtn » 03.11.20, 05:06
Hi all
I am having a Toshiba MQ02ABF050H hard drive
it boots up looks so ok
but sector cannot be read
I have done like instruction https://blog.acelab.eu.com/2045.html
and link https://blog.acelab.eu.com/pc-3000-for- ... rives.html
and link https://forum.acelab.eu.com/viewtopic.php?f=147&t=7732
but all failed
help me please!
northwind
Re: MQ02ABF050H cannot read sector
Postby northwind » 03.11.20, 09:00
Does terminal say
SIGNATURE SCAN FAILED
thanhtn
Postby thanhtn » 04.11.20, 03:00
@nothwind Didn't see that message
northwind
Postby northwind » 04.11.20, 09:26
Could you connect terminal and power up the drive? And post screenshot of terminal window here?
Postby AJ2008 » 04.11.20, 17:15
Looks like a NAND issue to me, needs to be flushed over terminal
thanhtn
Postby thanhtn » 05.11.20, 03:35
northwind wrote:Could you connect terminal and power up the drive? And post screenshot of terminal window here?
there is a notice like in the picture, my friend
thanhtn
Postby thanhtn » 05.11.20, 03:38
AJ2008 wrote:Source of the post Looks like a NAND issue to me, needs to be flushed over terminal
Can you guide me to fix it?
MasterT
Postby MasterT » 05.11.20, 17:40
Toshiba SSHD (Hybrid drives)
Work with Service Area --> HDD Configuration Changing --> Flash Permanent Cache --> OFF
Or issue >NVA command in terminal and Restart Drive.
Postby AJ2008 » 06.11.20, 11:26
thanhtn wrote:Source of the post
MasterT wrote:Source of the post Toshiba SSHD (Hybrid drives)
thanhtn
Postby thanhtn » 09.11.20, 15:43
MasterT wrote:Toshiba SSHD (Hybrid drives)
Flash permanent cache parameter: it was faded and cannot be turned on or off
MQ02xxx I think it's not supported
Filipp_TS
Postby Filipp_TS » 13.01.21, 13:31
It's supported.
And NAND can be disabled - that's a solution.
As was mentioned - connect terminal adapter, launch Toshiba utility and select ang MQ****H family name (important that 'H' in the end of family name).
then go to Work with Service Area --> HDD Configuration Changing --> Flash Permanent Cache --> OFF as was mentioned.
Then check sector access - should be available.
Return to “Toshiba native”
Users browsing this forum: Bing [Bot] and 1 guest
