Hi Friends
Good Day..
WD40NDZW-11MR8S1 this particular slow reading its seems bad sector or one of the head is damaged
used unlocked board 800022 now able do anything
original converted the board to SATA
ID reading properly and unable to read the sector
please help if anyone know for the solution
Modules directory address............... : 39 542
ROM Modules:
ROM version............................. : 00.0CT
ROM F/W version......................... : 0000000C
Overlay F/W version..................... : 00.0DT
Servo F/W version....................... : 0A.04
Heads number............................ : 10
Heads number in use..................... : 10
Heads map............................... : 0,1,2,3,4,5,6,7,8,9
Service area:
Dir data................................ : Yes
Permanent overlay....................... : Yes
CFG data................................ : No
Self encryption drive................... : Yes
Master Password......................... : No
User Password........................... : No
SED tech mode lock...................... : No
UA writing.............................. : Granted
WDC WD40NDZW-11MR8S1
Re: WDC WD40NDZW-11MR8S1
This is Spyglass2 and it's locked in new way.
Your best bet is to try and recover it in its original USB PCB.
We have done a few of these v2 Spyglass
You can use the SATA PCB for the v1 to gain SA access (turn off relo collect & relocation in HDD ID) and build head map in DE, then switch back to USB PCB
We use PC3000 Portable with the USB Host to access the drives, create a new DE task then copy the head map created in the previous task with SATA PCB
Clone away
Clone away
Paradog84 wrote:Source of the post We have done a few of these v2 Spyglass
Clone away
I'm dealing with my first of these (a 5TB model) now. Let me know if there's a better way, but here are a few extra details that have cost me a lot of time:
1) When building the headmap as a SATA drive, make sure that you don't start it as a 4K sector drive, or the map won't match the later USB version correctly. (Make a regular 512b sector map as the SATA drive to copy to the USB DE project). (I'm not sure if there's a way to fix that if the SATA headmap was already created in 4K, but I was getting 'catastrophic errors' due to that until I had the 512b regular headmap.)
2) When setting up the USB DE project, make sure the USB drive is started in pc3k WD utility, start DE, choose the pc3k utility version, and then I had to choose the 2nd option "Use Ata read sectors ext (0x24) through SCSI ATA Translation", otherwise I couldn't see all the data when DE Browsing. After starting the project, I shut the project down (to allow changing the headmap file), then copy the head.map file from the SATA project's version to the USB project's spot, then reopen the DE USB project with the copied headmap file.
Without these settings right, it would be easy to miss a ton of data, since some will show up, but a lot of it won't.
- Abdurrahim.sopon
Clone away
great information
Abdur rahim sopon
Dhaka-1205 Bangladesh
mobile:01912-881685
skype:rahim3720
mail:Rahim@datarecoverybd.com
www.datarecoverybd.com
mobile:01912-881685
skype:rahim3720
- d_d_recovery
- User
Abdurrahim.sopon wrote:Source of the postParadog84 wrote:Source of the post We have done a few of these v2 Spyglass
Clone away
great information
Just to be clear. That does not work on Spyglass2.
d_d_recovery wrote:Source of the postAbdurrahim.sopon wrote:Source of the postParadog84 wrote:Source of the post We have done a few of these v2 Spyglass
Clone away
great information
What part of it doesn't work?
- d_d_recovery
- User
Can you create a head map with a Slyglass2?
This is my first one, and the recovery isn't finished, but if the WD50NDZW-11MR8S1 is indeed a 'Spyglass2' drive, it certainly seems to have allowed a headmap to be built while using SATA PCB.
- d_d_recovery
- User
Yes that is Spyglass2. So good to know.
d_d_recovery wrote:Source of the post Can you create a head map with a Slyglass2?
Yes you can and it does work
- firdousnet
Is it ok to clear relo from SMR drives ?
firdousnet wrote:Source of the post Is it ok to clear relo from SMR drives ?
it's not OK because Relo-list has different from previous Marvell families structure.
The research of this isue is in progress now.
Paradog84 wrote:Source of the postd_d_recovery wrote:Source of the post Can you create a head map with a Slyglass2?
I have a WD40NDZW-11MR8S0 SpyGlass2 drive (firmware 02.01A02) and can create a head map, but it's completely wrong. It only maps a tiny fraction of the sectors to 2 out of 10 heads.
How were you able to create a head map?
MY CASE HEAD MAP DONE BUT USER ARE ENCRYPTED TO HDD V2 HOW TO DECRYPTED
Best regards,
Vijayan MBA
Raminfotech Data Recovery
http://www.raminfotechdatarecovery.com
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Vijayan MBA
call 7092114411/22
