Seagate momentus 5400.6 LBA & ABR Error
ddcywf
Postby ddcywf » 21.05.20, 06:00
hi,
I am facing LBA error followed by ABR error while performing the Quick Disk Analysis (snapshot attached). I don't understand what to do with it. I am also unable to open the dis drives which gives "Root Dir is not valid operation aborted" error. Kindly help in recovering the data.
northwind
Re: Seagate momentus 5400.6 LBA & ABR Error
Postby northwind » 21.05.20, 08:57
There is one partition missing. The one that you show is not your main partition.
Run raw recovery on your drive and show results here.
Nick_TS
Postby Nick_TS » 21.05.20, 09:07
Are all sectors readable on the drive?
ddcywf
Postby ddcywf » 28.05.20, 07:56
Dmitriy_TS wrote:Source of the post Are all sectors readable on the drive?
Editing of sectors shows zeros
ddcywf
Postby ddcywf » 03.06.20, 05:49
northwind wrote:Source of the post on your drive and show results here.
The Raw Recovery results snapshot is attached herewith
raw recovery 1.jpg (287.13 KiB) Viewed 20263 times
ddcywf
Postby ddcywf » 05.06.20, 08:26
The problem still persists kindly help
d_d_recovery
Postby d_d_recovery » 05.06.20, 17:27
If you look at your first picture posted, look at the status registers. You have issues with this drive. I suspect its bad heads. Can you post the terminal readout.
Postby digitalsupport » 06.06.20, 13:29
+1, drive has problems that needs to be taken care of before imaging.
Return to “Data Extractor”
