strange problem on HN-M101MBB
Moderator: Garry_TS
mojimorady
Postby mojimorady » 17.03.20, 11:43
Dear guru
Accept my regards
these days I am involved with a samsung drive , the problem is mostly like WDC drives when they face Module 32 problem , I mean the hard drive becomes ready , get in Samsung window , but when I click on anything it goes to busy . for example I started to create a back up of modules , it went to busy , I turned it off / on I could back up 3 of modules and then busy state , turned off/on and backed up 3 more modules ,etc.
this is also a part of terminal messages
PwrOn RRO1x @ H0
Table) cos = -397824, sin = 218368
Coeff) cos = -127193, sin = 87747
DiskSlip : 64 [SrvTrk]
DiskSlip : 85 [SrvTrk]
PwrOn RRO1x @ H2
Table) cos = -399616, sin = 227840
Coeff) cos = -120076, sin = 31318
DiskSlip : 65 [SrvTrk]
DiskSlip : 80 [SrvTrk]
TgtCyl: 832
Hd: 0 Zn: 0 Avg.:- 189
TgtCyl: 266976
Hd: 0 Zn: 1 Avg.: 936
SVCAL(0080,0000)-->PASS
DAM
RecordValid Ok : 0407E47D 0007E41D
ReadyTime = 3689389 us
ENG>mS1 00000003
SK C:162940 H:0
SC(U)..4111/-87
UD..OK : -87
PK_4 C: 42 H:0
I don't know where the problem is .
i will be very appreciated for your guidelines.
regards
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Filipp_TS
Re: strange problem on HN-M101MBB
Postby Filipp_TS » 29.05.20, 10:08
Go to Utility status window (next button after power-on/off button) then open "Reading parameters" and move scroll to left side (set 3 or 4 read retry value).
Click OK and try to read SA modules, user area.
Note: this value is set in RAM and after re-power returns back to default.
Return to “Spin Point”
