hi to all
here there is a Samsung h.d.d : ST1000LM024
after spinning up it makes a sound just like a small clicking
the HDA was replaced with a completely healthy one but nothing changed , the HDA was swapped back to the donor , the donor works correctly .
Could any other reason causes such a problem ???
looking forward to hear the same experiences and the solutions
best regards
Mojimorady
ST1000LM024 UNKNOWN PROBLEM
Moderator: Garry_TS
- mojimorady
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
- digitalsupport
- User
Re: ST1000LM024 UNKNOWN PROBLEM
Post terminal output of the drive, in most cases it will give a hint and reveal whats wrong.
What is the preamp of the patient and what is the preamp of the donor?
- mojimorady
thank you DigitalSupport for your response
this is a part of terminal outputs :
S_0SR:0
AP:1 C: 7285-> 7285 H:0->0 AP Cnt: 10
UF 3 1stGrayErr Hd:0
UF 3 1stGrayErr Hd:1
SK C:130426 H:2
SR:1
AP:1 C:130426-> 7285 H:0->0 AP Cnt: 10
SK C:130291 H:2
SR:2
AP:1 C:130291-> 7285 H:0->0 AP Cnt: 10
SK C:130531 H:2
SR:3
AP:1 C:130531-> 7285 H:0->0 AP Cnt: 10
UD..OK : 6
PK_1 C: 31 H:0
GT:425
SC(L):4077/2
BE.N:23
LD..OK
UF6 GE
SK C:131662 H:2
AP:1 C:131662-> 7285 H:0->0 AP Cnt: 11
SK C:131095 H:2
S_0SR:0
AP:1 C:131095-> 7285 H:0->0 AP Cnt: 11
SK C:131119 H:2
SR:1
AP:1 C:131119-> 7285 H:0->0 AP Cnt: 11
SK C:131093 H:2
SR:2
AP:1 C:131093-> 7285 H:0->0 AP Cnt: 11
SK C:131332 H:2
SR:3
AP:1 C:131332-> 7285 H:0->0 AP Cnt: 11
UD..OK : 2
PK_1 C: 35 H:0
GT:424
SC(L):4079/36
BE.N:20
LD..OK
SK C: 1850 H:0
AP:1 C: 1850-> 7285 H:0->0 AP Cnt: 12
SK C:131289 H:2
S_0SR:0
AP:1 C:131289-> 7285 H:0->0 AP Cnt: 12
SK C:130565 H:2
SR:1
AP:1 C:130565-> 7285 H:0->0 AP Cnt: 12
SK C:131136 H:2
SR:2
AP:1 C:131136-> 7285 H:0->0 AP Cnt: 12
SK C:130606 H:2
SR:3
AP:1 C:130606-> 7285 H:0->0 AP Cnt: 12
UD..OK : 36
PK_1 C: 39 H:0
GT:424
SC(L):4078/35
BE.N:21
LD..OK
UD..OK : 35
PK_3 C: 27 H:0
GT:424
SC(L):4080/61
BE.N:23
LD..OK
SK C: 7147 H:1
AP:1 C: 7147-> 7285 H:0->0 AP Cnt: 13
SK C:130947 H:2
S_0SR:0
SK C:130426 H:2
SR:1
SK C:130291 H:2
SR:2
SK C:130531 H:2
SR:3
UD..OK : 6
PK_1 C: 31 H:0
GT:425
SC(L):4077/2
BE.N:23
LD..OK
UF6 GE
SK C:131662 H:2
SK C:131095 H:2
S_0SR:0
SK C:131119 H:2
SR:1
SK C:131093 H:2
SR:2
SK C:131332 H:2
SR:3
UD..OK : 2
PK_1 C: 35 H:0
GT:424
SC(L):4079/36
BE.N:20
LD..OK
SK C: 1850 H:0
SK C:131289 H:2
S_0SR:0
SK C:130565 H:2
SR:1
SK C:131136 H:2
SR:2
SK C:130606 H:2
SR:3
UD..OK : 36
PK_1 C: 39 H:0
GT:424
SC(L):4078/35
BE.N:21
LD..OK
UD..OK : 35
PK_3 C: 27 H:0
GT:424
SC(L):4080/61
BE.N:23
LD..OK
SK C: 7147 H:1
SK C:130947 H:2
Mojtaba Morady
- mojimorady
@ northwind
but I put the head back to the donor , it works correctly .
Mojtaba Morady
Switch Off HDD ,Then Clear Terminal ,Then start HDD After It Run For 10 Second Switch Off and Post Terminal ,You Have Missed Initial Terminal Output
- mojimorady
@ Amarbir[CDR-Labs]
thank you Man , I found a scratch on its platter .
Unfortunately there is another hdd here with the same problem and this is the terminal messages as you told :
ÿ
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI Found
*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI FoundU
S_0SO_1
SPU@28'C,4726mV
IS=3
CLA ..36/76
HO..OK
HO RPM=744 OK
AC 1463
ST..Skip..OK
mS1 00000003
GT:420
SC(L):4149/60
BE.N:23
LD..OK
UF6 GE
SK C: 5725 H:2
[DF_TMOUT0:0000:0000]
AP:1 C: 7285-> 7285 H:0->0 AP Cnt: 0
SK C: 12893 H:0
AP:2 C: 7285-> 7285 H:0->0 AP Cnt: 0
SK C: 28162 H:0
SR:0
AP:2 C: 28162-> 7285 H:0->0 AP Cnt: 0
UF6 GE
SK C: 35423 H:2
SR:0
UF6 GE
SK C: 26747 H:2
S_0SR:0
AP:2 C: 7284-> 7285 H:0->0 AP Cnt: 0
UF6 GE
SK C: 32103 H:2
SR:1
AP:2 C: 32103-> 7285 H:0->0 AP Cnt: 0
SK C: 35264 H:0
SR:0
SK C: 34999 H:0
SK C: 34891 H:0
SR:0
AP:2 C: 34891-> 7285 H:0->0 AP Cnt: 0
SK C: 35361 H:0
SK C: 35145 H:0
SK C: 34969 H:0
SR:0
SK C: 34700 H:0
SR:0
SK C: 34913 H:0
S_0SR:0
SK C: 34673 H:0
SR:1
AP:2 C: 34673-> 7285 H:0->0 AP Cnt: 0
SK C: 34892 H:0
SR:2
AP:2 C: 34892-> 7285 H:0->0 AP Cnt: 0
SK C: 36331 H:0
S_0SR:0
UF6 GE
SK C: 36395 H:2
looking forward to hear from you
regards
ÿ
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
S_0SO_1
SPU@28'C,4726mV
IS=3
CLA ..36/76
HO..OK
HO RPM=744 OK
AC 1463
ST..Skip..OK
mS1 00000003
GT:420
SC(L):4149/60
BE.N:23
LD..OK
UF6 GE
SK C: 5725 H:2
SK C: 12893 H:0
SK C: 28162 H:0
SR:0
UF6 GE
SK C: 35423 H:2
SR:0
UF6 GE
SK C: 26747 H:2
S_0SR:0
UF6 GE
SK C: 32103 H:2
SR:1
SK C: 35264 H:0
SR:0
SK C: 34999 H:0
SK C: 34891 H:0
SR:0
SK C: 35361 H:0
SK C: 35145 H:0
SK C: 34969 H:0
SR:0
SK C: 34700 H:0
SR:0
SK C: 34913 H:0
S_0SR:0
SK C: 34673 H:0
SR:1
SK C: 34892 H:0
SR:2
SK C: 36331 H:0
S_0SR:0
UF6 GE
SK C: 36395 H:2
regards
Mojtaba Morady
In This Case Try and Boot FRom Plater 00 , head 00
