Seagate Laptop Thin sshd.
Model: ST500LM000
FW: DEMC.
The Hard Drive does not spin. Terminal shows following details.
ERROR: Flash LED 9C1C - No clumps available - cannot get new active clump
Clump Parametrics:
Clump = 016E
DataType = 0000
ModeFlag = 01
EraseCount = 00008267
EraseFailCount = 00
ProgramFailCount = 00
WeakReadCount = 01
UncorrectableECCError = 00
---SOC PSM Command History---
Cmd#/PsmCmd Clump Offset Length LbaMid LbaLow LbaBits39To32 Options Status DestClump DestOffset
0002 016E 0040 0001 0000 001E 0000 9000 0080 C207 D3AE
0102 016E 0040 0001 0000 001E 0000 9000 0080 C207 D3AE
0002 015F 0040 0001 0000 001E 0000 9000 0080 C207 D3AE
0F02 018B 00C0 0001 0000 001E 0000 9000 0080 C207 D3AE
0E0A 0182 00C0 0001 0000 001E 0000 8000 0021 C207 D3AE
Flash Statistics:
BridgePSMDriverID = 0x0009
FlashID 98D7 8493 72D7
Flash Manufacturer: Toshiba19nm
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps = 0x0400
LBAsPerCluster = 0x0020
LBAsPerClumpMLC = 0x4000
LBAsPerClumpSLC = 0x2000
ClustersPerClumpMLC = 0x0200
ClustersPerClumpSLC = 0x0100
DefragClumpThresholdInSectors = 0x2000
UserSLCMaxSizeInClumps = 0x0180
NumberOfPotentiallyWrittenClusters = 0x0002
DefectListRevisionKey 0x0002
SLC Clumps 0x01A7
ActiveClumpInfo
Active Journal Clump 0183 Offset 1740
Active Anchor Clump 0005 Offset 17C0
DType 0000 Read Cache Clump 037F Offset 0000
DType 0001 Read Boot Clump 0279 Offset 0000
DType 0008 Dirty Write Cache Clump 0182 Offset 00C0
DType 0009 Dirty Boot Clump 0186 Offset 0040
DType 0011 Clean Write Cache Clump 0185 Offset 16C0
DType 0012 Clean Boot Clump 018F Offset 1820
DType 001A SIM Clump 0172 Offset 2000
--- ALF RFS Recorder ---
--- Recorder prints backwards: newest to oldest ---
IARCount Status Clump ClumpSentinel FunctionOrigin
ALFRecorder:
End of ALF Recorder Trace
Thin SSHD Error Flash LED 9C1C - No clumps available - cannot get new active clump
Re: Thin SSHD Error Flash LED 9C1C - No clumps available - cannot get new active clump
I have tried using this blog. https://blog.acelab.eu.com/pc-3000- ... -work.html
After patching the rom. It gives following error. Can not access the terminal.
Request spin / disc table recovery
ERROR: Flash Led 9C17 - RestoreALFTablesToDRAM Failed - could not recover data from Tables Clump
Clump Parametrics:
Clump = 0001
DataType = 00FF
ModeFlag = 03
EraseCount = FFFFFFFF
EraseFailCount = 07
ProgramFailCount = 07
WeakReadCount = 1F
UncorrectableECCError = 07
000A 0001 001E 0002 0000 001E 0000 C200 0026 C207 D1AE
050A 0001 0000 0020 0000 0000 0000 C200 0026 C207 D1AE
0400 000C 0000 16C7 0000 0000 0000 C000 0001 C207 D1AE
0300 0001 0000 0001 0000 0000 0000 C000 0080 C207 D1AE
0200 0001 0020 0001 0000 0000 0000 C000 0080 C207 D1AE
Flash Statistics:
Combo Mode
SLC Clumps 0x01A7
ALFRecorder:
Clump Parametrics:
Clump = 0001
DataType = 00FF
ModeFlag = 03
EraseFailCount = 07
WeakReadCount = 1F
Flash Statistics:
Combo Mode
SLC Clumps 0x01A7
ALFRecorder:
solved
After using donor pcb and patient rom.
