840 EVO Busy - no logical access
odedshankar
Postby odedshankar » 19.09.19, 08:27
Hi Guys,
Got this 840 EVO SSD, it stays busy.
I shorted the safe mode pins and connected the terminal as required.
When i get to the Loader Uploading - the only option that works is the second one 840EVO_LD.ldr which has Logical option access OFF and Enc ON.
Unfortunately that is the only option that works when choosing the loader.
After that i get - as can be shown on the attached log:
"Loader uploading
Code name............................... : 840EVO_LD.ldr
Write HDD microcode
Write Main Firmware..................... : Ok
SSD status:
Loader uploaded......................... : Yes
Reading password information............ : Ok
Now i still not getting any right size and it still in safe mode, but i try to create DE Task and image that but getting not right size and all black sectors when imaging.
Can you please advise what can be done.
Re: 840 EVO Busy - no logical access
Postby Roman_TS » 19.09.19, 10:31
Hello. Please note that ACELab doesn't provide technical support in forum. If you want to get help with this case, please make a ticket:
odedshankar
Postby odedshankar » 19.09.19, 12:48
Hi Roman,
Thank for your reply. I know mate, i also submitted a ticket as you mentioned to be handled by your support team.
This Forum entry is aimed for the general forum members in case they have some insights into this case from past experiences.
Cheers
Postby Roman_TS » 19.09.19, 20:57
If existing loaders are not works with your drive, I'm doubt that other PC-3000 owners could help in this case.
mojimorady
Postby mojimorady » 05.08.20, 09:19
HELLO , WAS YOUR PROBLEM SOLVED ???
i FACED WITH SAME PROBLEM AND I WONDER HOW YOU SOLVED YOURS ? (IF IT WAS SOVED!!)
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
odedshankar
Postby odedshankar » 05.08.20, 11:01
Hi mojimorady, unfortunately this case wasn't solved at the time.
Return to “840 EVO Series”
