Using PC-3000 with a UPS
markrocketrepairs
Postby markrocketrepairs » 29.01.19, 12:25
I have a ups that will put the computer to sleep/hibernate or shutdown the computer if there is a power cut.
No matter if I use sleep or hibernate when the PC-3000 data extractor is running and the system is put to sleep or hibernate when it wakes back up it can no longer "talk" to the drive.
It keeps stating a SATA error of some kind.
Is there anyway round this by using a special power mode or switch when starting the software?
hipo
Re: Using PC-3000 with a UPS
Postby hipo » 30.01.19, 09:34
When you create task select Modify MBR for target drive. So in next restart Windows don't mount target drive.
Sistrum Data Recovery
http://Www.datarecovery.mk
markrocketrepairs
Postby markrocketrepairs » 30.01.19, 09:51
I will try that and report back
Sam A
Postby Sam A » 20.11.19, 03:16
There is a button on the right side labeled 'reset PC3000 utility' in the column where 'hardware reset', 'software reset', 'recalibrate', etc. is.
Clicking on that will fix this. I often put my PC3000 PC to sleep to swap destination drives and have to do this after waking to restore normal functionality.
