I have Hard disk wd20nmvw-11av3s2 and I like to Transfer Rom from usb pcb to Donor pcb
I believe this drive has slow response issue so planing to change from usb pcb to sata
so i am looking for any documentation can help me to transfer the rom from this 2060-771961-001 rev A TO 2060-771960-000-REV A
This 2060-771961-001 has 12 pins so i like to know how we can setup com connection
how i can transfer rom information from one pcb to other pcb
wd20nmvw-11av3s2 Rom Transfer from usb pcb to Donor pcb
- Paulfromsurrey
Paul Patil
PC Plus Computing
Data Recovery Services
Business IT Services and Computer Repair Services
https://pcpluscomputing.com/services/Da ... -Services/
PC Plus Computing
- digitalsupport
- User
Re: wd20nmvw-11av3s2 Rom Transfer from usb pcb to Donor pcb
How to make a Com connection is right here https://forum.acelab.eu.com/viewtop ... 155&t=7397
How to transfer via Boot ROM mode you will find here: https://blog.acelab.eu.com/boot-rom ... rives.html
- Paulfromsurrey
Thank you Digital but the problem is in this model
there are two rows of 6 pins
not sure where the com connection should be connected which adapter is good to use
Paul Patil
PC Plus Computing
PC Plus Computing
You can use the WD 2.5 adapter. (see photo for connection)
- Paulfromsurrey
Thank you Blizzard
Paul Patil
PC Plus Computing
PC Plus Computing
- radovanhlavacek
Hello I have question on this topic... wd20nmvw-11av3s2, PCB 2060-771961-001 REV A. I found two SATA boards 2060-771961-001 REV A, REV P1, P2. Which PCB is compatible?
- jcrepairhdd
radovanhlavacek wrote:Source of the post Hello I have question on this topic... wd20nmvw-11av3s2, PCB 2060-771961-001 REV A. I found two SATA boards 2060-771961-001 REV A, REV P1, P2. Which PCB is compatible?
Hi from my experience the most compatible would be 2060-771961-001 REV A. All screws line up as well unlike the others I have tried.
