this HDD.
Modules operation read then error is servo.
But sa region change in rom. Then restart HDD. Drd DSC ready. Loader load. Sa region change in ram. Then all modules read and write ok. Smart clear reli list clear etc.
Head test read and write ok. All modules check all crc is ok in modules. No error in modules. Old rom write. Then tick tick tick.
Pls tell me how to solve this issue.
Data is important
Wd1600avvs-63L2b0
Re: Wd1600avvs-63L2b0
Probably some modules are not original.
Make a hotswap donor and see if it behaves the same way. If it is - some modules are not original, if it isn't then make a hotswap and image the drive
prashantasus, try to edit head map in RAM.
Maxim_TS wrote:Source of the post prashantasus, try to edit head map in RAM.
That was my first thought, then I though a little more and realized that this drive has only one head
- prashantasus
Hot swap same donor but tik tik tik.
Head map only 1 head.
prashantasus wrote:Source of the post Hot swap same donor but tik tik tik.
Unlikely a drive you could be able to do.
- prashantasus
Doomer sir how to solve this . Pls pls pls
Sir hot swap tik tik tik
New 01 create manually and tell me which mods are important
I think 02 03 04 31 33 40 41 50 51 and ek to e9
