WD600BB-00DKA0 - ROM damaged
jojo2012
Postby jojo2012 » 08.08.18, 08:23
Hi there,
I’m handled this case that comes from another lab.
The original PCB (2060-001159-006) was dead, and I have the donor PCB. Unfortunately the original flash ROM has been damaged, or rather a pin is detached.
There is the possibility of restoring it or rebuilding it from the SA like with the Marvel?....or is this a hopeless case?
Thanks guys for any hint or help
Re: WD600BB-00DKA0 - ROM damaged
Postby digitalsupport » 08.08.18, 18:44
jojo2012 send me a close up of the area where the pin is missing.
Have good experiences with this.
Postby Amarbir[CDR-Labs] » 09.08.18, 04:03
might be you can try programming few roms of same drive family in your donor pcb ,These drives can work like this imho
jojo2012
Postby jojo2012 » 10.08.18, 15:27
digitalsupport wrote:Source of the post jojo2012 send me a close up of the area where the pin is missing.
Thanks for the help DigitalSupport. I don’t have a close up of damaged area, I want to do it with a digital microscope. I wanted to try to write a few ROMs of the same drive family as suggested by Amarbir and another guy from another support. These drives do not have adaptive in ROM.
jojo2012
Postby jojo2012 » 21.08.18, 10:14
Well, case solved.
Wrote ROM in kernel mode from a drive of the same model in the database and it worked like a charm.
Return to “WD Caviar Cyl 32”
