Hi to all
I have WD 2tb Desktop HDD with ID& Capacity . But the terminal shows the following message. due to the error i am not able to access the sector
RAM:
SA SPT.................................. : 1740
ROM:
Read ROM................................ : HDDs ROM reading error Data request error - Device Error Detected: "CA FLUSH ALL GOT CANCELED"
Service area:
SA dir reading (ID)..................... : CA FLUSH ALL GOT CANCELED
SA dir reading (ABA/CHS)................ : No S/A regions info avalable
Can Anybody tell the meaning of " CA FLUSH ALL GOT CANCELED" AND what is reason behind
Betty
WDC WD20EZRZ-00Z5HB0 with Error "CA FLUSH ALL GOT CANCELED""
Re: WDC WD20EZRZ-00Z5HB0 with Error "CA FLUSH ALL GOT CANCELED""
Update:
I have changed the PCB , but result is same
I can check for you, I will message you at skype
Data is accessible now
- datasolution
HELLO ALL,
I have same hdd Model : WDC WD20EZRZ-00Z5HB0 .Error is like
Techno mode key
Debug Stop Code......................... : Unknown debug stop code. 1BC19
RAM:
ROM:
Modules directory address............... : 181 583
ROM Modules:
ROM version............................. : 15.0BC
ROM F/W version......................... : 0015000B
Overlay F/W version..................... : 15.0BC
Servo F/W version....................... : 02.67
Head Map Reading Error.................. : Head map check sum error
Read ROM
Into file............................... : <HDD Profile>\Data\ROM\ROM_15-0BC_15-0BC_02-67.bin
Ok
Read ROM modules
Module : 0A............................. : Ok
Module : 0B............................. : Ok
Module : 20B............................ : Ok
Module : 30............................. : Ok
Module : 47............................. : Module ID 47 reading error Data request error Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 0D............................. : Ok
Module : 4F............................. : Ok
I tried sa region block and get sa access.According to blog slow fix and mod 0002 edit after xxxxxxxxx 0ZH500000 fill 00 00
and recalculate checksum and write mod.Sa unblock and fw restarting again same thing arise .Pls anyone correct me where is the problem ?
Thanks In Advance.
Techno mode key
RAM:
ROM:
ROM Modules:
Read ROM
Ok
Read ROM modules
Thanks In Advance.
datasolution, try this solution as well: http://blog.acelab.eu.com/pc-3000-h ... rives.html
- datasolution
Thank you,Maxim.I have tried it.But after power off and on again it becomes busy and only err reg there.No id.
thanks again and hope for reply.
datasolution, please contact us in Support System http://ts.acelab.eu.com/ with new ticket.
datasolution wrote:Source of the post Thank you,Maxim.I have tried it.But after power off and on again it becomes busy and only err reg there.No id.
solved or still not solved ?
I already sent a message to the user offering to look at this case but so far I heard nothing so I guess he solved it or raised a ticket with Ace who solved it
- datasolution
HELLO AJ2008,
sorry at that time customer take away his hdd and actually i was not able to read your post but today i have same hdd with folowing err.
Techno mode key
RAM:
ROM:
Modules directory address............... : 170 095
SA defects assigned..................... : 4
ROM Modules:
ROM version............................. : 01.7VC
ROM F/W version......................... : 0001007V
Overlay F/W version..................... : 01.7VC
Servo F/W version....................... : 02.63
drive spins and clicks than stop and gives no led.Than when enter utility it shows err like above.After sa region edit drive reachs ready states and able to access sa.i have fix slow responding and than restart with sa allow.Same results.This drive shows 5 heads and headmap is 0,1,2,4,5 .I have similar hdd with same problem.Normally this hdd has 4 heads and headmap is 0,1,4,5.Pls help me if possible.May be sometime time region problem so i am not able to see your notification.So pls forgive me and pls do some needful.
thanking you
Techno mode key
RAM:
ROM:
ROM Modules:
thanking you
