No!
I can't find anything...
I tried several solutions offered from
Data Inspection/001 - Complex Analysis Metod/(when started, I have info):
- DataInspestion-ComplexAnalisys.png (26 KiB) Viewed 20207 times
After that, when I tried some
Rusult of Preparation, FAILD...
... some of them, which I started = unsuccessful.
From TASK log =- ECC not detected! If the ECC is not corrected before the quality of the result can get worse!
- Autodetecting is impossible. Enter the parameters manually!
- The partition header is incorrect! It is advisable to use table and hard disk analysisSometimes:- ECC not detected! If ECC has not been corrected before the quality of result may be worse!
- Autodetection is impossible. Write parameters manually!... ... ...
I do not know how and what to do manually!
After the analysis, I tried with these "method",which are offered as solutions = unsuccessfully! Translator (Type 2) AU6389,AU6980,AU6981,AU6982 : 10 %
Translator (Type 3) Memorystick : 10 %
Translator (Type
iCreate i5128-LG : 10 %
Block number (Type 1) [0x0000] : 42 %
Translator (Type 26) PS2232BD(C), PS2237-F : 6 %
id 2526;
id 3132;
Translator (Type 28) PS2134CE : 6 %
Translator (Type 32) PS2136CF : 6 %
Translator (Type 31) PS2134CH(I), PS2136CC : 6 %
Translator (Type 27) PS2136CC : 6 %
