Here is the log:
Code: Select all
Techno mode key
RAM:
SA SPT.................................. : 885
ROM:
ROM Modules:
ROM version............................. : 14.DRP
ROM F/W version......................... : 001400DR
Overlay F/W version..................... : 14.DRP
Servo F/W version....................... : 05.D0
Service area:
Permanent overlay....................... : Loaded
HDD ID reading.......................... : Ok
Solve "slow responding" problem (RAM)
HDD ID writing.......................... : Ok
Defect candidates reading............... : Ok
Defect candidates writing............... : Ok
Ok
Soft reset ...
SED key checking
There are no key dir modules
External encryption key checking
UA key reading:976 769 056.............. : Ok
SA key reading:Copy 0................... : Ok
SA key reading:Copy 1................... : Ok
UA key reading:976 770 435.............. : Ok
UA key reading:976 769 032.............. : Ok
Encryption.............................. : INIC1607E
SA key reading:Copy 0................... : Has been already read
SA key reading:Copy 1................... : Has been already read
UA key reading:976 773 128.............. : Ok
SED key checking
Is it possible that this is a 128-bit encrypted drive? The bridge IC is an Initio INIC1607E.
