Difference between DCM in 3.5 WD
Re: Difference between DCM in 3.5 WD
The date is pretty far off, but this might work: https://www.ebay.com/itm/Western-Digita ... SwUlxaLdXv
Good info. Thanks.
I eventually found an affordable drive (2000 years later) for under $100 and solved my case.
DataMedics wrote:And, while I've never yet tried it, I suspect that Diablo 3S family may be cross-compatible. The ariel density is slightly different, but close enough they might use the same heads.
These are interchangeable
Thanks for confirming that. I'd always assumed it, but never yet tried it. I've been keeping a list of cross-compatible families here: https://www.data-medics.com/forum/cross ... html#p6487
I'll add that pairing to the list.
