RoseWood after Rom patched "Verify ALF FW signature failed"
Hemendra
Postby Hemendra » 08.09.17, 05:45
I have detected segate rosewood 1 TB hdd.
Model : ST1000LX015-1U7172
Serial : WES29VPA
Firmware : SDM1
Capacity : 1 TB (1 953 525 168)
I can't access the SA Area.
so As per your blog I have patched the Rom.
after patched rom the hdd gives error message in terminal "Verify ALF FW signature failed". No detection, No spin.
Attached the rom file.
I doubt the bug in newer version software.
Thanks,
ROM_WES29VPA_A89139AF.rar
(367.25 KiB) Downloaded 670 times
Arihant
Re: RoseWood after Rom patched "Verify ALF FW signature failed"
Postby Arihant » 11.09.17, 10:59
Which version of pc3k you have?
Only ACE-lab can check and solved this issue. or you can try with different version pached rom.
Thanks,
Thanks,
Amit Shah
Arihant Data Recovery, India
Hemendra
Postby Hemendra » 11.09.17, 15:32
version 6.3.15
build 6.3.15.6463
Pl. patched the rom and send me again if you have higher or different version.
Hemendra
Postby Hemendra » 15.09.17, 13:22
Resolved the case, without the paching rom.
300ddr
Postby 300ddr » 29.09.17, 22:38
This probably happened because you wrote the wrong using "common" family or the wrong family. Next time, find the family code in ROM after reading, then re-enter utility using that family, then write ROM and it will succeed.
Hemendra
Postby Hemendra » 03.10.17, 07:20
How to identify family code from rom?
300ddr
Postby 300ddr » 03.10.17, 18:34
Open ROM, click SAP button, see highlighted characters in this pic: https://www.dropbox.com/s/9js00pwtecyltxs/sap.jpg?dl=0
Hemendra
Postby Hemendra » 03.07.18, 06:04
LarrySabo
Postby LarrySabo » 03.07.18, 16:29
300ddr wrote:Source of the post Open ROM, click SAP button, see highlighted characters in this pic: https://www.dropbox.com/s/9js00pwtecyltxs/sap.jpg?dl=0
404
That file isn’t here anymore!
300ddr
Postby 300ddr » 03.07.18, 19:21
Here ya go Larry.
Note: latest versions of PC3K show the name of the family now -- next to the family code.
LarrySabo
Postby LarrySabo » 03.07.18, 21:18
Thanks, Brian.
Postby Amarbir[CDR-Labs] » 06.07.18, 17:32
300ddr wrote:Source of the post This probably happened because you wrote the wrong using "common" family or the wrong family. Next time, find the family code in ROM after reading, then re-enter utility using that family, then write ROM and it will succeed.
Each and every drive i have patched till today is with common utility ,The only thing i do is that in the rom capacity i enter all zeros so what it auto detects size
300ddr
Postby 300ddr » 11.07.18, 23:11
What do you mean by this?
Nick_CT
Postby Nick_CT » 08.10.18, 13:43
I'm struggling with this as well.
ST1000LX015
Patched ROM and wrote it to drive, in terminal now get error:
Have written patched ROM with correct Rosewood utility, tried Common utility, put ROM capacity as 0 to autodetect. I've patched lots of Rosewood ROMs with my PC3K, this is the first one that has a problem. Running 6.3.15
Any ideas please?
osity
Postby osity » 01.02.24, 02:47
Pretty sure this is a hybrid, needs special attention and won't unlock as easily as others.
