SSHD ST500LM000
pcrecovery
Re: SSHD ST500LM000
Postby pcrecovery » 26.01.17, 13:16
I have an ST1000LM014 with LVD5 (has the 8GB NAND flash onboard). It took me months to find the correct donor ROM . I tried LVD5 taken from a similar model, but it was NOT compatible and i had to find the exact same model drive with close match on serial (W77 here btw) and identical LVD5 fw.
After moving adaptives and writing ROM, i get NOTHING but BSY.
with original ROM on donor PCB i also get only BSY.
Actually the only way i get any terminal output at all is with original PCB + original ROM.
drive never spins up no matter what is attempted.
I will try some of the above-mentioned methods , including use of loader, etc. but we need an expert write-up detailing the problem and solution.
Masterclass
Re: SSHD ST500LM000
Postby Masterclass » 27.01.17, 05:39
NAND is dead in the drive.
book14
Re: SSHD ST500LM000
Postby book14 » 01.08.17, 12:46
pcrecovery wrote:Source of the post Actually the only way i get any terminal output at all i
pcrecovery wrote:Source of the post I have an ST1000LM014 with LVD5 (has the 8GB NAND flash onboard). It took me months to find the correct donor ROM . I tried LVD5 taken from a similar model, but it was NOT compatible and i had to find the exact same model drive with close match on serial (W77 here btw) and identical LVD5 fw.
I have just recovered one with the same fw. I properly know how to do but need the patient driver on my hand.
The key problem is not on ROM but Nand .
Nick_TS
Re: SSHD ST500LM000
Postby Nick_TS » 04.08.17, 21:43
Here is the standard solution for SSHD.
Unfortunately, the standard solution doesn't work on LVD5 FW version :(
But if you will be able to fix the drive then please let us know :)
book14
Re: SSHD ST500LM000
Postby book14 » 07.08.17, 12:04
Dmitriy_TS wrote:Here is the standard solution for SSHD.
blog.acelab.eu.com/pc-3000-for-hdd-sshd-drives-what-is-it-and-how-to-work.html
This link is not found.
Nick_TS
Re: SSHD ST500LM000
Postby Nick_TS » 21.08.17, 21:58
book14 wrote:Source of the post blog.acelab.eu.com/pc-3000-for-hdd-sshd-drives-what-is-it-and-how-to-work.html
Try to login the blog with the forum credentials.
book14
Re: SSHD ST500LM000
Postby book14 » 29.08.17, 09:43
Dmitriy_TS wrote:Source of the post
Still can't find the page, can you check it again?
ThomasH
Re: SSHD ST500LM000
Postby ThomasH » 03.09.17, 02:26
I could be wrong, but I think the LVD5 indicates a Lenovo FW, (LVxx)
like DExx is Dell
HPxx is Hewlett Packard
etc.
So LVxx firmware donors are going to be hard to find since they'll probably have to be a Lenovo laptop pull.
I'm going to be receiving one of these soon, but haven't had a LVD5 yet, and it seems I've just been lucky so far doing PCB swaps on DExx models. Will we really need to have an exact match for FW to use a donor PCB for this, or is there some other workaround?
Nick_TS
Re: SSHD ST500LM000
Postby Nick_TS » 20.09.17, 19:14
Dear Thomas,
To solve the NAND Cache issue on LVD5 FW version, you can downgrade the FW version to LVD3 or LVD1 and use the standard Kahuna procedure.
lcoughey
Re: SSHD ST500LM000
Postby lcoughey » 15.12.17, 15:24
I've done 2 cases this week without changing the PCB by using the same process I used when I posted about it here - https://www.recoveryforce.com/forums/vi ... =demd#p549
AYESHA KHAN
Re: SSHD ST500LM000
Postby AYESHA KHAN » 08.04.21, 16:03
I have this same drive and same issue
What to do can anyone help me plz
