Boot ROM Mode - Schematics For 2.5" SATA Interface
Postby Amarbir[CDR-Labs] » 14.04.16, 20:15
Hello Ts Staff,
When i Got My PC 3000 UDMA-e I did Not Get Any PC 3000 WDC USB/SATA Adapter .Please Refer To This Image
What i am Trying To Do Is " Something Few Guys Should Learn "
1 : I Have a WD5000KMVV-11TK7S1 With Dead ROM
2 : I Read The ROM Using a External Programmer
3 : Opened The Rom Dump and Used Acelab Hexedit " Hexedit Has Beautiful Western Digital Marvel Plugins "
4 : Using One Plugin " I Copied And extracted All Rom Modules " To Seperate Files
5 : So Now Either I Can Program That ROM Using External Programer / Boot Rom Adapter With ROM Ver 003008C " This ID Can Be Checked By Module 4F Extracted Before "
6 : Once That is Done i Will Copy All Extracted Rom Modules From Defective ROM To The One I Programmed
7 : Voila Magic :D
PS : Could You Please Tell Me The Schematics Of this Adapter " So That i Can Use a Alternative Myself ".Will That Maxtor Adapter Also Work ? " What Pins To Connect It To :?:
300ddr
Re: Boot ROM Mode - Schematics For 2.5" SATA Interface
Postby 300ddr » 18.04.16, 23:09
This may be your answer. I got this pic from ace but with no instructions. Please let me know if it works. http://i.imgur.com/N9fhAa5.jpg
Maxim_TS
Postby Maxim_TS » 29.04.16, 13:55
Amarbir[CDR-Labs], WD 3,5" and 2,5" adapters are availabve for purchasing. Everyone can contact ACELab sales managers to get those adapters.
Postby Amarbir[CDR-Labs] » 30.04.16, 08:53
Maxim_TS wrote:Source of the post Amarbir[CDR-Labs], WD 3,5" and 2,5" adapters are availabve for purchasing. Everyone can contact ACELab sales managers to get those adapters.
Maxim ,
I Have The 3.5" WDC Adapter But Not The SATA/USB One .Can You Share The Schematic With Me As i Can Then Make a Crude Version Till i Do Not Order My Update Of PC 3000 Flash And Add These Addons Into It .Can Someone Help Me Who Already Has This Adapter Please The 2.5" SATA/USB
Maxim_TS
Postby Maxim_TS » 06.05.16, 18:47
Dear Amarbir[CDR-Labs], we can not share the schematic, I hope you understant why :) They are not very expensive, so we always advise to purchase them from ACE sales. Today I've solved one case with WD USB with Slow Responding using this 2,5" WD adapter, and we didn't need to solder a SATA adapter or find a SATA PCB, so I think it worth to buy.
300ddr
Postby 300ddr » 10.05.16, 19:30
I'm about to order these new adapters, but I can't tell from the photos exactly how they will connect. These new PCBs don't have "pins" coming out, but it looks like the new terminal adapter requires them.
What am I missing? How do you connect this Terminal adapter...
To this PCB?....
Maxim_TS
Postby Maxim_TS » 16.05.16, 16:08
300ddr,
Expand view USB
Collapse view
Expand view SATA
Collapse view
300ddr
Postby 300ddr » 16.05.16, 17:48
I noticed the picture of "to this PCB..." (in my previous post) was missing. Fixed now. Is connection to this new PCB possible?
Maxim_TS
Postby Maxim_TS » 17.05.16, 13:16
300ddr wrote:Source of the post Is connection to this new PCB possible?
Yes, but you need to solder the wires from "USB HDD" pins in adapter to terminal pads
in USB PCB in the same order like if PCB has the pins and you connect it directly.
Expand view
Collapse view
It can be enough to use only three pins: white, blue and violet.
300ddr
Postby 300ddr » 17.05.16, 18:34
Dang, was hoping there was going to be an easier solution. Thanks.
Maxim_TS
Postby Maxim_TS » 20.05.16, 12:51
300ddr, at least it works, and it's better than no solution at all ;)
jojo2012
Postby jojo2012 » 29.07.16, 10:29
I read the ROM in boot mode on WD5000LMVW-11VEDS6 using Toshiba adapter, and connected it as a usb2.0.
300ddr
Postby 300ddr » 30.07.16, 03:27
The model in question has different terminal connection. Look at pics above.
Hary
Postby Hary » 15.12.16, 00:28
All WD 2,5" USB drives (not slim)that has pins on PCB in two raws including this one from topic can be connected using Toshiba adapter as on attached picture
and this new L or as You wish J shape PCB can be connected via soldering 3 cable
:D
300ddr
Postby 300ddr » 15.12.16, 00:57
Hary -- wow! This is exciting to hear/see, thanks for sharing!
Users browsing this forum: Bing [Bot] and 1 guest
