Moderator: Garry_TS
Pavel_TS wrote:Source of the post I suggest you to solder SATA connector to original PCB and check https://yadi.sk/i/GjNDQseXctuD9
Also your donor PCB could be not compatible. Compatibility criteria is same same platformId (same family and processor), take care about it
