how to recover mac filevault encryption
oldman
Postby oldman » 30.11.15, 02:10
I cloned the drive, but not perfect, it was encrypted by Mac FileVault, how do I decrypt it.
Thanks.
Phil
ps: I only have user password, not the recovery key.
Re: how to recover mac filevault encryption
Postby AJ2008 » 30.11.15, 09:53
connect clone over usb/firewire to the mac and it should mount and attempts to access it will prompt you for the password - once entered you will have access to the data
oldman
Postby oldman » 30.11.15, 16:47
AJ,
thanks for your reply, it does not mount as the clone is not perfect.
What info I have to clone for mounting it?
Phil
Nick_TS
Postby Nick_TS » 30.11.15, 21:33
Hello oldman,
In DE you can clone used space only on destination drive then connect it to Mac.
oldman
Postby oldman » 01.12.15, 02:52
Hello Dmitriy,
Thanks for your reply.
I have made full clone, but there are bad sectors.
Nothing happen if I connect the cloned drive to Mac, as no partition info.
Where is the password for FileVault saved?
Thanks for your help.
Phil
Nick_TS
Postby Nick_TS » 02.12.15, 13:08
Hello oldman,
We don't know where is FileVault password located.
Did you connect destination drive to Mac (where this file system was created)?
oldman
Postby oldman » 03.12.15, 19:22
Hi Dmitriy,
Yes, I connect the cloned drive to original Mac.
Are there any better, stronger ways to make clone/read?
I can not read front sectors start from 0 to 409640, but the heads are good as reverse clone is perfect.
Thank.
Phil
Postby AJ2008 » 04.12.15, 14:23
What drive is it you have cloned? Maybe there are improved reading algorithms you can try to re-read bad blocks?
Nick_TS
Postby Nick_TS » 07.12.15, 16:04
Yes, sotimes bad blocks can be caused by pending issue.
oldman
Postby oldman » 07.12.15, 18:18
AJ and Dmitriy,
It is a Hitach apple drive,
5K750-500, HTS547550A9E384.
I can not read the first few sectors 0,1,2,
I seem to get the 409640, but not before, and after.
Phil
300ddr
Postby 300ddr » 09.12.15, 20:02
Try Diskwarrior after connecting clone to Mac. See if it can see/repair the partition. If so, just move the data from the "preview" --> do not REPLACE the catalog file.
oldman
Postby oldman » 09.12.15, 21:27
Hi 300ddr,
The drive was encrypted by filevault, do you think that diskwarrior can build it?
Best Regards.
Phil
300ddr
Postby 300ddr » 09.12.15, 21:51
It can repair FileVault (but depends on how damaged it is). Once you open DW, if it can see the volume it was ask for password.
oldman
Postby oldman » 14.12.15, 22:16
Sorry to say, the vol can not been seen as I do not get the first 3 sectors. :(
If I get from other drive, but the password does not work out.
Thanks a lot.
Phil
Postby DataMedics » 23.12.15, 22:34
Here's a thought for you. UFSExplorer Professional Recovery has the option to decrypt a partition using password. If I'm not mistaken original FileVault uses AES-CBC encryption, and FileVault 2 uses AES-XTS. Both of which are supported by the program. Might take a bit of playing with settings to get it right, but should work in theory.
Return to “Data Extractor”
